Chain Tension Questions- Mtbr.com
Results 1 to 2 of 2
    Klein sits on shelf now..
    Reputation: AdroitBreaker's Avatar
    I recently converted the beater to a single and I have been playing around with gear ratios to try and find the perfect tensioner-less gear combination. I was running a 32/20 with a rear D to keep the chain taught. I removed a link and I can almost get the 32/20 to fit. The first pic shows how soooo very close it is. Would a half link give me the length I need? (although I don't think this is the gear ratio I want)
    In the second pic I basically want to know of this is a good idea. Can I use rear D like this until I get a tensioner? If this is a bad idea, I'll put my Dremel away and put the other pulley back on.
    KgB
    KgB is offline
    SNGLSPD
    Reputation: KgB's Avatar
    A half link may work
    It's a good idea to have one on hand anyway.You may still need a tensioner though.
    you can also dremel your dropouts or axle and I hear the ENO hubs work pretty well also.
    Your derailler looks like it should work,not a pretty sight though.
    Good luck.
    I've been inside too long.
  1. 9spd chain on an ACS Claws freewheel... good idea?
    By jean-seb in forum Singlespeed
    Last Post: 03-01-2004, 07:40 AM
  2. Best way to keep a chain clean?
    By gottjr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-19-2004, 07:04 PM
  3. Spoke Tension specs for various rims?...
    By Ricko in forum Wheels and Tires
    Last Post: 02-04-2004, 06:14 PM
  4. chain tension ????
    By stoom in forum Singlespeed
    Last Post: 01-22-2004, 09:39 PM
  5. short vs med vs long derailleurs??
    By gettingsquirrely in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-20-2004, 01:32 PM
