Chain Tension Question (ENO content)- Mtbr.com
Results 1 to 28 of 28
    Just A Mountain Biker.
    Reputation: blaklabl's Avatar
    Mar 2011
    So, have a question for the group. I have an ENO eccentric hub, and I recently changed my gearing from 32:17 to 32:18. At first I kept the chain the same length, but it pushed my wheel too far forward and I was getting tire buzz under cornering. So, I added the minimal amount I had to (1-link) and this is what the result is:
    That is with the hub rotated full back (max tension). Is that too slack? I donít want to get out on the trail and find out itís a problem.
    My other option would be to run a narrower rear tire without massive side knobs and bringing it forward wouldnít be as much an issue. I just got my WI freewheel so Iím not changing that, and I am getting WI M30 cranks with a 32t ring this week so Iím pretty tied in to that gearing for the time being. Narrower rear tire is the least expensive option I believe, but if the way I have it now will work Iíll continue to run it. Thanks!
    (Before adding chain link. I know it looks good, but the knobs on the tires were too far into the chainstay/B.B. junction):
    Sent from my iPhone using Tapatalk Pro
    MTBR: Your dad's online mountain bike forum.
    Feb 2014
    That would be too slack for my taste, but if you can't pull on the chain sideways and derail it, you're 'probably' okay.
    I would look at running a half link if possible, or clipping the corners of the shoulder knobs if you like that tire as a rear. If neither of those are an option, I'd go for the smaller tire.
    Mar 2011
    Quote Originally Posted by Shinkers View Post
    I donít think a half link would work for me with a NW chainring. I thought about cutting the knobs but realistically it would just probably be frustrating as those tomahawks have huge thick side knobs. Iím thinking an Ikon 2.2 or something like that would work well, but I am going to try and use it tomorrow night and hope not to derail it.
    Combat Wombat
    Reputation: BrianU's Avatar
    4-bolt 104mm standard rings are fairly easy to come by and a KMC Z610 chain, which comes with a half link, could be cheaper than a new tire.
    Mar 2011
    Quote Originally Posted by BrianU View Post
    I just invested in a WI M30 crankset with their direct mount ring, believe me that ring is not cheaper than a tire.
    Mar 2015
    Just run a tensioner. Then your problems are solved. Seems like a whole lot of work to avoid the easy and cheap solution.
    Mar 2011
    Quote Originally Posted by Jefflinde View Post
    The point of the eccentric hub is to avoid a tensioner.
    Mar 2015
    Yet here we are...
    Mar 2011
    Yet here we are...
    I was only asking if I was missing an option with my current setup. Thanks for sharing your idea, Iíll pile it up with the others.
    Mar 2015
    Not trying to be a dink but from what I have read the ebb and hub options are very limited in success for non-SS frames. I have two vertical drop out bikes and have gone to tensioner with great success. I am able to go from a 34/13 to a 34/22 with no chain adjustment. It might net be the preferred option but it will certainly be successful
    Mar 2011
    It was flawless until I changed my gearing, for over a year. Iíll just figure out an adjustment, not changing anything else until the cranks and ring get here this week. Itís a PITA when v-brakes are also involved. Thatís what I get for changing. Thanks for your insight, no worries.
    Mar 2011
    So, I went on a fairly long off-road night ride tonight, and didnít have one hiccup. While it ďlooksĒ not as tight as Iíd like it, it appears to be mechanically sound.
    Reputation: MRMOLE's Avatar
    Quote Originally Posted by blaklabl View Post
    I've found chains to wear and lengthen fairly rapidly on my single speed bikes and would guess since your hub is already at its adjustment limit your problem is only going to get worse. If your willing to risk losing your chain (which may involve a crash) there's a good chance after a couple of rides you'll be able to remove the extra link you added and have enough chainstay clearance to eliminate the rub. I personally wouldn't be comfortable running that much slack in my chain and since you don't care to run a tensioner would consider the narrower/less aggressive side knob option the best way to go.
    Mole
    Combat Wombat
    Your problem can be an issue on any SS bike frame and have run into it with my Kona Unit. When I first built up my Kona, I bought a crank that came with a 32T ring. I used a cog that gave me pretty much the same gear inches as the 34/20 I used on my other bike. The slider was either slammed all the way forward, with the chain tension too tight, or after adding a link, all the way at the end. I was avoiding a half-link, because I wanted to use a DM ring and they seem to all be NW. I also wanted to be able to just use any 8-speed chain and not worry about that one special piece to make things work. I end up switching over to a 34/20 setup, which for me put my sliders in the ideal place of about 80% of the way forward. I had been able to find online, a killer deal on a 34T OneUp Components DM chainring and had an extra 20T cog, so it was not an expensive fix. WI is nice stuff, but you rarely ever find deals on it. Somewhere, I have seen a table that showed chain lengths based on ring/cog size and gear inches. This helped me out. Maybe someone else on here knows what I am talking about. I'll look around and see if I can dig it up.
    Edit. I found the chain length calculating info.
    http://eehouse.org/fixin/index.php
    When you open the page, scroll down and select "HTML form".
    Reputation: dbhammercycle's Avatar
    Since I would use the rotation of ENO to tension the chain thereby helping to keep the ENO in place as well, I would think it's too loose. However, on my MUSS with a Surly hub and AB Oval I get about that slack when the ring is at a "low" point and have had no issues with the chain popping off the WI freewheel. As long as you can ride with it and the ENO doesn't slip, I'd say you're good.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Mar 2011
    I'm going to give an IKON 2.2 a shot. I like the gearing I am running, not interested in a tensioner, just want to get to the "set it and forget it" point now. The bike is nearing completion and I'd like to stop spending so much time changing and adjusting everything.
    Thank you everyone for taking time to offer your ideas, hope you all had a nice weekend.
    Feb 2017
    What about flipping the chainring? Not sure what the white direct mount setup is like, but i think other direct mount chainrings are "dished". That would give you the few mm of clearance you need.
    Mar 2011
    Ikon did the trick. I can now run it far forward in the eccentric cycle with no rubbing, and have good chain tension.
    Mar 2011
    With the White Industries crankset and DM ring...smooth
    Feb 2017
    Fancy!
    Sent from my REVVLPLUS C3701A using Tapatalk
    lpt1
    Reputation: lpt1's Avatar
    blaklabl, You can use 34:19 combo, that left eccentric hub position exactly as it was in your previous 32:17 setup, and approximate You very close to desired 32:18 gear ratio.
    Mar 2011
    But would have had to add a chain link, correct? I'll keep that in mind when I want to spend another $200 on WI chainring and FW
    lpt1
    Yes, one full link, exactly. Rule of Four in action.
    $200 SS aluminium proprietary-mount chainring?!!
    Mar 2011
    Quote Originally Posted by lpt1 View Post
    No, 90 for chainring and 80 for FW. So 170. White Industries shit isnít cheap, but I have lusted after it for a long time.
    Pretty much this exactly.
    lpt1
    You don't need to buy a whole new freewheel, but only 'outer gear' part, it usually cost half of complete freewheel.
    Mar 2011
    Thank you, that's a good point.
    And as far as the proprietary thing, I *think* the chainring mounting pattern is RF Cinch. I have had a cinch crankset in the past and the spline pattern looks identical, and realistically their attachment/tensioning method on their new M30 cranks and BB is basically the cinch design, so I wouldn't be surprised. I haven't asked if the splines are the same because i have a thick ass expensive chainring to wear out first!
    Don't be afraid to go with a half link and ditch the NW chainring and go with a standard non-ramped ring . If your chain line is good and your tension is good, a NW isn't required.
  1. Crazy high spoke tension, or tension meter off?
    By tuvok in forum Wheels and Tires
    Last Post: 04-25-2016, 05:25 PM
  2. What does max spoke tension for your rim mean? Average tension?
    By happyriding in forum Wheels and Tires
    Last Post: 03-23-2014, 11:03 AM
  3. Replies: 0
    Last Post: 11-29-2013, 12:14 AM
  4. chain guide for White Industries ENO
    By jeff smith in forum 29er Components
    Last Post: 03-05-2012, 10:32 PM
  5. Replies: 13
    Last Post: 12-29-2011, 06:14 PM
