Chain Tension problems- Mtbr.com
Results 1 to 5 of 5
    Single Speed Junkie
    Reputation: crux's Avatar
    I am rinning a blackspire 32t chainring on a set of Race Face Next square taper cranks with a ti 17t White Industries rear freewheel. Problem that I have is when the chain is properly tensioned in one position of the cranks when rotated it will loose or gain tension depending on where the cranks are sitting. Everything is new and should not be out of round due to wear, so what is my problem, except that I am unable to figure this problem out for myself.
    USB Rep'n
    Reputation: namaSSte's Avatar
    Quote Originally Posted by crux
    if your bike has horizontal dropouts, simply use a tug on the driveside (or on both if you're like me and fancy overkill). problem solved. if you have vertical dropouts, you might need to convert your hub axle to a solid one with track nuts to get the thing locked down tight. then again, perhaps I am misunderstanding the entire problem...
    though hope is frail, it must prevail - Taj Weekes
    betam eh-wud-eh-HA-lehu y
    eh-nay Ityopia!
    It's not uncommon.
    The chainring is likely just a bit off center on the crank spider. Set the crank in position where the chain is tightest, loosen the chain ring bolts and the chain will back off a bit and retighten. Rotate the cranks, check the tension and tweak it as necessary.
    Reputation: itsdoable's Avatar
    Sheldon Brown has a big write up on this. Basically the bolt circle on the cranks or chain ring (or both) are not exactly centered on the BB, thus the chain tension varies depending on crank position. Pretty common as most cranks & chain rings are designed for deraillures, so a slight offset is not usually noticable. Also, the Next Crank's chain ring tabs are inserts that are held by the granny bolts, so slight differences in how they seat will affect the centering.
    Follow Sheldon's instructions, lossen the chain ring bolts slightly, see if you can work the chain ring to the center by taping the chain when it is tight, and/or rotate the chainring to another position.
    Could also be a slight our ot round on the freewheel too, but that is unlikely with the White Ind. (Shiamno & ACS are another story!)
    Cheers,
    Tom
    USB Rep'n
    Quote Originally Posted by itsdoable
    Cheers,
    Tom
    Ive read this and clearly misunderstood the poster's question. Good advice Tom.
    eh-nay Ityopia!
  1. Eggbeater or Frog - bad knee
    By Jdubya in forum General Discussion
    Last Post: 05-07-2007, 03:58 PM
  2. Help! Problems dropping chain
    By SS_Belmont in forum Singlespeed
    Last Post: 06-10-2004, 10:27 PM
  3. Adjusting chain tension - Bianchi SISS
    By AK47 in forum Singlespeed
    Last Post: 04-27-2004, 07:20 AM
  4. > 1/8" chain stretch - time to replace the chain rings?
    By journey in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2004, 05:05 PM
  5. chain tension ????
    By stoom in forum Singlespeed
    Last Post: 01-22-2004, 09:39 PM
