Chain tension not tensioner- Mtbr.com
Results 1 to 3 of 3
    Reputation: azimiut's Avatar
    Feb 2014
    I built a nice SS gravel bike I ride on canal paths and other low climbing gravel paths. I had a tensioner on it I did not like, was doing some messing around and found I am right there at the "magic gear". it was a converted bike with vertical dropouts. I can easily take the wheel off with the chain set how it is now. I am just wondering though. the chain feels fairly tight on there. Is there a proper amount of chain deflection for single speed to know if it is too tight or too loose?
    Dont make me go all Jonathan Winters on this gas station.
    Aug 2010
    You should be able to back pedal with no resistance. Too much tension and the pedals will not spin freely. This will wear out the drivetrain pretty quickly.
    Aug 2010
    To add to that, more than an inch total (not an in each way up and down!) and you are definitley too loose. You run the risk of dropping the chain.
  1. Replies: 0
    Last Post: 06-23-2016, 11:36 AM
  2. Best Single Speed Chain Tension / Chain Guide
    By bank5 in forum Singlespeed
    Last Post: 06-24-2013, 07:16 AM
  3. Singlespeed.... Chain tensioner vs chain tugs method
    By joehspicer@msn.com in forum Singlespeed
    Last Post: 04-14-2012, 02:23 AM
  4. Question on chain tension using a tensioner
    By -chs- in forum Singlespeed
    Last Post: 11-18-2011, 09:07 PM
  5. Replies: 17
    Last Post: 05-18-2011, 09:04 AM
