Results 1 to 13 of 13
Thread: Chain Tension?
    Just Joshin' ya!
    Reputation: PrincipalRider's Avatar
    Jun 2005
    Chain Tension?
    This might seem like a stupid question, but how much tension should I have in my chain? I have horizontal dropouts, so no chain tensioner is needed, but is it possible to over tension the chain by pulling too hard on the rear wheel (or tightening the screws that push the axle back too much)? Am I supposed to keep it pretty tight or should there be any slack? Sorry, I am a total newb to this singlespeed thing. I am totally into it though.
    Just for context, I have a Voodoo Nakisi Monstercross bike.
    Getting a dropper post is like getting a bidet. I didn't know I needed one until I get one and boy, does my ass thank me.
    Bro
    Bro is offline
    Content from my avatar
    Reputation: Bro's Avatar
    Dec 2010
    Too much tension means too much friction. Some people say it kills the bearings, I just say it's really, really hard to pedal that way. And probably not good for the bearings too.
    Tension the chain tight enough so that it doesn't drop while you're riding, and loose enough so that there's no binding through the cranks' rotation.
    Sometimes, I question the value of my content.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    1/2" (1" total) deflection for a 'typical' 26" wheel'd frame is a good rule IMO A bit less for BMX. -a bit more for 29r.
    Really, it should feel kinda loose-ish, but not so loose that bumps would jar the chain off a ring...A good chain-line really helps.
    -If you can come close to 'derailing' the chain by hand; it's too loose.
    Honestly... ahh I give up
    Reputation: rearviewmirror's Avatar
    1/2 inch deflection in the middle of the chain is about right, and make sure you're pedaling it and checking to ensure it's loose enough at the tightest spot in the chain.
    Draft College Republicans
    Ovaries on the Outside
    Reputation: umarth's Avatar
    The best way to see if you are doing it wrong is if the chain falls off. If you have a SS chain and cog, you can get away with having a fairly loose chain, and then you don't have to **** with dialing the tension. Save that **** for when you want a perfect fixed gear set up. Cause then it matters.
    ~Disc~Golf~
    Quote Originally Posted by rearviewmirror View Post
    great point!
    Fat & Single
    Reputation: ozzybmx's Avatar
    Ive had easily 3 inch deflection and havent fixed it, as long as your chainline is spot on, you should be sweet.
    Its no rocket science, keep err straight and it will be fine.
    BTW ive noticed if you are a bit tight on some hubs it skips pawls after freewheeling.
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Just Joshin' ya!
    Jun 2005
    Cool. Thanks all.
    Dive Bomber
    Reputation: jackspade's Avatar
    As tight as smooth you backspin.
    playin hooky
    Reputation: struggleT's Avatar
    Quote Originally Posted by jackspade View Post
    Lyrics, definitely!
    Just Joshin' ya!
    Jun 2005
    Well, I have about 1/2 inch deflection, everything seems smooth. I took it out for a trail ride and there was no skipping and I did not lose the chain. It seems great.
    M_S
    M_S is offline
    Nov 2007
    Just barely enough so the chain doesn't drop. As much slack as possible is best for the drivetrain and for pedaling efficiency.
    - Simon
    Just Joshin' ya!
    Jun 2005
    Quote Originally Posted by M_S View Post
    Hmm, I don't think I have that much. My chainline seems spot on, maybe I will give it a bit more slack.
