Chain tension- Mtbr.com
Thread: Chain tension
    Chain tension
    how tense are you?
    Two riders were approaching; and the wind began to howl.
    Reviewer/Tester
    Reputation: Rainman's Avatar
    Quote Originally Posted by jayssmtbde
    how tense are you?
    Quite tense... 1/2" max up and down on the bottom run with the pedal tensioning the top run...all tensions being equal...
    R.
    It is inevitable ...
    what is best for durability's sake? i run it until it's barely hanging on; then again, i haven't hit any singletrack with it set up thus
    808+909 = Party Good Time
    Reputation: chumbox's Avatar
    I run it almost as tight as I can without it binding, making silly noises or anything unusal. If it looks remotely bouncy I start to look at it because when they come off they are dangerous as. Probably stems from the time my road fixie chain flung off on a busy main road... about two days after I thought maybe I should install a front brake on it... lucky
    The tighter it is the more efficiency I reckon I feel when pedalling... especially up steep hills.
