chain suggestion- Mtbr.com
    chain suggestion
    for a geared bike I usually just go with Shimano XT or something. But for SS I want some input on what is a good solid chain to cut down on the chance of it breaking.
    I'm using a hub (XTR 960 i believe) that was meant for gears so I'm going to need a thinner chain I assume, as opposed to a BMX style which is more burly and meant for SS applications.
    any suggestions? or can you point me to where this has been discussed already.
    thx
    aka baycat
    Reputation: Ryan G.'s Avatar
    Used an 8 speed SRAM and KMC 610 without problems.
    Mtbr Forum Sponsor - Homebrewed Components
    Quote Originally Posted by mtbnj
    thx
    The hub has no bearing as to what chain you run. I'd suggest a good 8 speed or 3/32" bmx chain. 9 and 10 speed chains are a little narrow and will fit tight on true SS specific gearing.
    Quote Originally Posted by ISuckAtRiding
    good advice. I was reading on this a few moments ago. That is the best way, those chains are the best bet I would think.
    I guess Surly makes these types of cogs and spacer kits.
