Chain ring bolts for SS on Jenson.com- Mtbr.com
Results 1 to 6 of 6
    I have a Truvita crank set that I'm going to pair with a Niner 32t chain ring. Are there any chain ring bolts (preferably on Jenson.com for free shipping) that you would recommend?
    Are there SS specific chainring bolts or should I go with a double like - FSA Torx Alloy Chainring Nut/Bolt Sets > Components > Drivetrain > Chainring Bolt | Jenson USA Online Bike Shop
    surly inbred
    Reputation: TroutBum's Avatar
    Quote Originally Posted by bank5 View Post
    No such animal, really... just get something in steel sized for a single ring.
    Sugino Single Chainrng Bolt Set > Components > Drivetrain > Chainring Bolt | Jenson USA Online Bike Shop
    (I assume you are using one chainring & no bash.)
    Quote Originally Posted by TroutBum View Post
    Yep, no bash, just one niner SS chainring. As far as size: is 6mm better for a single chainring at 8mm would be better two chainrings?
    What you need are "short stack bolts". Any local bike shop that specializes in BMX parts will have them.
    Reputation: asphaltdude's Avatar
    Ride more!
    Reputation: AlexCuse's Avatar
    Did you get the chainring used? I think I have the same one, and the mounting bolts it came with actually weren't long enough to accomodate a bashguard on my crank (e13 xc, but I imagine the ends of the spider are a fairly standard thickness - I definitely went from a 1 + bash setup on a truvativ crank to the same on that one without any bolt replacement).
    Yeah I only carry cans cause I'm a weight weenie.
