Chain Recommendations?- Mtbr.com
Results 1 to 10 of 10
    Reputation: PanFry's Avatar
    Nov 2007
    I am currently running an ENO Crankset with a Chris King Stainless Cog. That said I need to know what the best chain to use is. I tried to put on a SRAM 8spd. today and it fit the King Cog PERFECTLY but the spacing wasn't quite right on the White Industries Chainring.
    Recommendations?
    Thank you all in advance,
    PF
    trail rat
    Reputation: slocaus's Avatar
    The dozens of other threads on this topic see the KMC and SRAM chains most recommended.
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    Misfit Psycles
    Reputation: nogearshere's Avatar
    Mar 2005
    Quote Originally Posted by PanFry
    Recommendations?
    something is amuck.
    8 spd chains are 3/32 chains - 3/32 chains (be they CALLED 8spd or singlespeed) make for the best single speed chain (in my opinion).
    unless there is wear on the chain or the ring of some unnatural or generally expired nature they should all marry together quite nicely.
    can you describe your spacing issue a little more clearly? pictures?
    Expert of the Internet.
    BECAUSE I SAID SO
    Reputation: OldHouseMan's Avatar
    I'm using the same White Industries carnk and Chris King cog and have no problems with the Sram 870 chain.
    I only ride bikes to fill the time when I'm not skiing.
    Reputation: stephen11364's Avatar
    Sram Pc870
    Any thoughts on SRAM PC870 8 Speed Chain?
    Quote Originally Posted by stephen11364
    Like it just fine! Using it with a 34T Surly SS steel chainring, and a White Industries ENO freewheel. No fit issues of any kind.
    I also have a 34T Surly chainring but am using a 17T Surly cog.
    Reputation: Richard Roma's Avatar
    SRAM PC870
    worn ring?
    I'm also using a WI ENO crank and King cog. I run SRAM 8-speed chains and replace them as soon as they show any wear on a Park chain checker. I'm guessing your chainring is probably worn. Mine's about due too....
    If white is the "new black", then thanks but I'll stick with the old black...
    Any remarks on the sram 850?
