Chain Ratios- Mtbr.com
Results 1 to 10 of 10
Thread: Chain Ratios
    Jan 2009
    Chain Ratios
    Just got a new SS (El Marichi SS Ltd.) and it came with 33 x 18. My old bike had 32 x 18 and I was wondering if adding a 20 to the rear would be the same as what I had. Lots of hills here in Tahoe and want to make it easier to climb, or just put in a 21.
    PS. I love the bike
    Reputation: SlowPokePete's Avatar
    Mar 2006
    Plug in your info here ... Sheldon Brown's Bicycle Gear Calculator
    SPP
    Rigid.
    Reputation: drofluf's Avatar
    Dec 2010
    Assuming that your old bike had the same size wheel you're pretty close at the moment. 33/18 gives a ratio of 1.8333, 32/18 1.7778. So to get the same with your 33 ring you'd need something like a 18.5 tooth cog. Not sure that anyone is making that size anymore
    In my experience there's more to it than just the ratio: the tyre and geometry come in to play as well. In your place I'd stick where you are at the moment until you get used to the bike unless you're finding it a lot harder or have moved to a hillier area
    If you need me I'll be at the bar
    Quote Originally Posted by rushman3 View Post
    PS. I love the bike
    33x20 will be easier to pedal but will have a lower top speed than 32x18
    If you had 32x18 before and want something easier, I'd go with either a 19 or 20 tooth cog. A 21 in the back would be a massive jump in ratio.
    Mar 2012
    I'd stick with what it came with... That's pretty darn close to your old gear and the change might suprise you for the better. Like I tell everyone - ride it, it's a bike!
    PS. I love the bike
    Gear down, you live in the "mountains", not hills - some other posters in flat states don't always understand real mountains. Try a 21t.
    Reputation: Shalom's Avatar
    Nov 2008
    You might be able to get close - Rennen Design do some cool chainrings in points. So you can get a 32.x tooth chainring. Might allow you to tweak it to what you want, if you absolutely have to match your last ratio.
    Otherwise, just ride it with a 20 or 21 and see whether it works for you.
    surly inbred
    Reputation: TroutBum's Avatar
    SS'ing it is usually about keeping things simple. Measuring tenths of anything seems rather focus-intensive (especially ****ing chainring teeth.) If you ain't feelin' what you got, add a tooth or two.
    Nov 2008
    Quote Originally Posted by TroutBum View Post
    That is the truth. Just giving options. Some people like technicality.
    Reputation: aegolius's Avatar
    Fixed Gear Calculator - Ratio & Skid Patch for all! very practical ratio calculator.
