Chain line trouble- Mtbr.com
    Chain line trouble
    Took my first foray into singlespeed last night. It was fantastic!!! Unfortunately, I have built up the singlespeed from a hardtail with vertical dropouts using a surly singulator. Apparently the chainline was off a little and the chain kept dropping. Definitely hindered my forward progress.
    Any advice on setting up the perfect chainline or determining/measuring correct spacing to achieve this for the rear. By the way, using a normal crank with middle chainring (32) and the rear is a busted cassette with 16T and spacers.
    Reputation: dubjay's Avatar
    Quote Originally Posted by joncmack
    What kind of spacers are you using? Are you able to rearrange the spacers a bit to adjust your chainline?
    Also, you may have better luck with a non-ramped cog in the rear. That might be the actual cause of your problem.
    Rollin' a fatty Moderator
    Reputation: DiRt DeViL's Avatar
    Humm, usual suspect. The rear cog from the cassette is meant to let the chain move up and down, that's why is ramped. That might be the issue.
    The singulator will help you achieve a good chain tension but will not prevent the chain from dropping. Before you get injured or have a close encounter with either the top tube or stem make yourself a favor and get a cheap cog and give it another try.
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    Two ways...
    The easiest and most effective way to set up your chain line is to simply look down the top of the chain from the back of the bike and see which direction the chain needs to go. Then add/remove spacers to achieve the correct spacing.
    If your chainline is off by about the width of the crank spider, put the ring on the opposite side. You can use spacers on the ring to accomplish this but it's far easier to adjust the spacers in back.
    Ken
  1. popped a chain link -- time to replace chain??
    By journey in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-29-2005, 03:27 PM
  2. Should I shorten my chain?
    By Vulcan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-08-2005, 09:20 PM
  3. What do you use to lock up your bike?
    By LavaPunk in forum General Discussion
    Last Post: 02-06-2005, 01:20 AM
  4. Good info on bike locks.
    By 2melow in forum General Discussion
    Last Post: 02-06-2005, 01:02 AM
  5. Noisy chain when in middle ring- HELP!!!!!!!
    By HPilot in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-01-2005, 10:49 AM
