Chain Length Calculators?- Mtbr.com
Results 1 to 3 of 3
    Reputation: dubjay's Avatar
    Is there any kind of formula I can use to determine how many chain links difference there is between different gearings?
    Example - if I go from a 32:18 to a 38:16, how many links would I need to add (if I need to at all)?
    Quote Originally Posted by dubjay
    It's approximately 1 link per tooth. However that doesn't account for the difference in angle between the cog and ring, which for a same-length chain will move the wheel forward a bit (or BB backward if EBB) when you're running 34x16 as opposed to 32x18 for instance.
    If your wheel has room to move forward (or BB backward) right now in 32:18 then 4 links seem good. Otherwise you'll have to add 2 more and the wheel will end up a little further back (or BB forward).
    Maurice
    No Reputation!
    Reputation: Fastskiguy's Avatar
    Just think Convert!
    http://www.teambigtime.com/software/ssConvert.htm
    And the best part is that it's Mac OSX compatible (along with windooze)
  1. What do you use to lock up your bike?
    By LavaPunk in forum General Discussion
    Last Post: 02-06-2005, 01:20 AM
  2. Good info on bike locks.
    By 2melow in forum General Discussion
    Last Post: 02-06-2005, 01:02 AM
  3. Optimal chain length?
    By moxfyre in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-06-2004, 10:21 AM
  4. Paging Kman: Fuel 100 chain length??
    By CODMAN in forum Weight Weenies
    Last Post: 05-10-2004, 01:07 PM
  5. Calculating chain length for a SS conversion
    By od_the_roadie in forum Singlespeed
    Last Post: 04-02-2004, 03:58 PM
