chain help please- Mtbr.com
    Reputation: scottcan's Avatar
    chain help please
    I'm building up my first single speed and I am down to the last few parts. I am running HBC front and rear cogs. Can I just use a regular old 8,9,10 speed 3/32 chain? Any and all info is greatly appreciated. Many cheers!
    Reputation: Shalom's Avatar
    Nov 2008
    Depends. If you specified the HbC bits to be 3/32, then yes. If you specified that they be 1/8, then no.
    Go with an 8 speed sram chain. 850, 870 or 890. 9 and 10 speeds are expensive and don't last very long.
    Quote Originally Posted by scottcan View Post
    Dec 2009
    I built up my first SS a year ago with a scram 8 or 9 speed chain. It just broke today on a hard climb. I have later learned that KMC makes a 3/32 SS chain which appears to be much stronger.
    It mounted up fine and although I'm sure its more heavy then the scram I think it will not fail as easily.
  1. Old components on new frame .2" shorter chain stay - chain length reduction?
    By DPDISXR4Ti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-14-2011, 03:32 PM
  2. Replies: 8
    Last Post: 09-21-2007, 07:24 AM
  3. Dropping Chain with new Chain Rings, Chain and Shifters
    By mtbvfr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-13-2007, 04:05 PM
  4. Chain skipp / lashed and dropped from front chain rings during rough climb
    By peanut_man in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-04-2007, 01:45 PM
  5. 1st post Chain skipping/slipping.....and chain slap and chain derailing in jumps
    By bowunter951 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-03-2007, 05:37 PM
