Chain Derailing Issues- Mtbr.com
Results 1 to 8 of 8
    Ahhh the pain....
    Reputation: Raybum's Avatar
    All,
    I've been riding Single Speeds exclusively for like 5 years. Being a mechanical engineer that is a little OCD, I use my calipers and measure the crap out of stuff to be sure my chainline is solid. I've had the occasional chain derailing that typically I can blame on a worn chain. In other words (I run an oval AB chairing BTW), the lateral flexibility is higher on a worn chain and the lower length (not in tension) wiggles side to side more and climbs off the rear cog. AB oval rings naturally have a little tension variation and it seems like every time the derailing happens at the cog and when I'm full gas on some bouncy bit of uphill trail.
    Here are my thoughts...please feel free to share yours...
    1) The rear cog(running a Stainless Steel Wolf Tooth) flexes a little but doesn't have much in the way of chamfers on the tooth sides. In the stand, I can push the chain with my fingers and with little pressure get it to derail.
    2) Do some chains have more chamfers on the side plates? gotta figure that under a bunch of bouncy stuff, the slot on the chain is trying to find the tooth on the cog....chamfers help that rendevous to happen... running KMC 8.93 chains.
    3) Seems like tension doens't matter too much...obviously, first reaction is to tension is up, but that doesn't seem to help.
    thoughts?
    Reputation: socal_jack's Avatar
    Dec 2008
    I've always used singlespeed chains(lately 3/32 kmc 610HX), have never experienced this problem even with a loose chain, loose enough to hit the chainstay.
    Canfield Riot SS
    ROS9+ SS
    ROS9 SS
    GT Peace 9R SS
    Out spokin'
    Dec 1999
    I've always used cheap SRAM 8-spd chain on my singlespeeds. I singlespeeded nearly exclusively 10 years or so. During my SS years, the only time I dropped chains was when my chain was slack. I've used lots of different cogs, from Chris King to Surly including some custom ones. I'd have to dig them out of my garage to check, but IIRC they have chamfered teeth. Raybum, if you can derail your chain with minor pressure from your fingers then I think either your chain is too slack or the design of your cog is not optimized (hard to believe considering it's Wolf Tooth, a company that makes great stuff) or a combinition of those two factors. You said it's not chainline and it derails at the back, not the front, so factors are limited.
    I remember one time my chain was coming off constantly at the crank. Turned out the chainring had one bent tooth that kept kicking the chain off. You probably already checked for this. Have you tried a different chain?
    Good luck,
    sParty
    disciplesofdirt.org
    WillWorkForTrail
    Jun 2012
    You mention chain wear - how worn is the chain? Typically, I don't start having problems with the chain coming off unless the wear gets away from me - in other words, it's usually to the point I would replace the chain anyhow.
    Armature speller
    Sep 2004
    I've only had this happen on the thinner cogs. Never on a King or Surly.
    Reputation: Velobike's Avatar
    How much lateral flex is there in your chainstays?
    Too much and it will exaggerate the problem once your drivetrain is worn.
    This can be a problem with bikes designed for derailleur use because the designers have assumed the chains will be guided on to the rings and rear sprockets, ie they have built a bit more 'feel' into the chainstays.
    Latitude: 5736' Highlands, Scotland
    Feb 2014
    I'm running a wolftooth cog and cannot get my chain to derail just by pushing on it.
    I suspect some is up with your chain tension.
    Life's a Garden, dig it!
    Reputation: chuckha62's Avatar
    Quote Originally Posted by Velobike View Post
    This was my first thought as well. I've been riding SS on two different frames for about nine years and have never had a chain jump laterally.
    Are you running an SS specific rear hub? Or are you spacing it on a typical geared freehub body? I know you say you're measuring to the gnat's ass, but if the chainstay isn't flexing, maybe the cog is wandering a bit on the freehub body?
    "And crawling on the planet's face, some insects called, The Human Race..."
  1. Chain Keeps Derailing
    By Legbacon in forum Singlespeed
    Last Post: 09-16-2016, 04:04 AM
  2. Derailing question
    By dockt0r_wh0 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-10-2016, 05:12 PM
  3. Roof Rack Issues vs. Spare Tire Issues?
    By AmishAirline in forum Cars and Bike Racks
    Last Post: 04-27-2015, 05:54 AM
  4. my bicycle chain keeps derailing when i hit a bump
    By DominicTabuzo in forum Beginner's Corner
    Last Post: 10-25-2012, 11:46 AM
  5. Chain derailing when spinning crank backwards.
    By saveaux in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-25-2012, 04:43 PM
