carbon forkx- Mtbr.com
Results 1 to 3 of 3
Thread: carbon forkx
    ss= 800 lb. gorilla
    Jan 2009
    carbon forkx
    quick question 4 u guyzz in the know........i am 245 lbs, if i upgrade my outcast with a carbon fork, like the white bros, 4 example, with my weight, will it, or can it break??
    Get a walt works fork.
    http://waltworks.blogspot.com/2006/10/intro-post.html
    These will give you a forgiving ride & be tough as nails.
    nothing to see here
    Reputation: Stevob's Avatar
    The OnOne carbon fork has no weight or rotor size restrictions. The White Bros has a weight limit of 235lbs and rotor size limit of 160mm.
    edit to add: I'll be getting the OnOne, I'm only ~150lbs, but I want it because I run a 185mm front brake.
    I see hills.
    I want to climb them.
