Results 1 to 13 of 13
    Faster Than Your TV!
    Reputation: iconoclaSSt's Avatar
    Carbon bars and Thomson stems...
    ...any problems with this combo? I seem to recall hearing that older ('03-ish) Thomson stem clamps weren't exactly carbon-friendly, something about the machining of the inside clamp surface.
    True?
    "I still feel that variable gears are only for people over forty-five. Isn't it better to triumph by the strength of your muscles than by the artifice of a derailleur? We are getting soft...As for me, give me a fixed gear!'' -- Henri Desgrange, from an article in L'Equipe
    Wrench In the Gears
    Steel and teeth.
    Reputation: b1umb0y's Avatar
    Feb 2005
    Quote Originally Posted by iconoclaSSt
    True?
    No problems here (5+ years).
    b1umb0y
    Did a search & found what I was looking for...
    Quote Originally Posted by b1umb0y
    b1umb0y
    http://forums.mtbr.com/showthread.ph...tem+carbon+bar
    Wrench In the Gears
    ali'i hua
    Reputation: SlowSSer's Avatar
    only issue ive seen is dont over-tighten the thompson bolts. saw a bar clamp piece (that the right word) at the LBS not too long ago that was cracked in the middle, right thru where it says "thomson". and it was being used with a carbon bar.
    torque wrenches are your friend!
    Steamroller
    Reputation: Mattman's Avatar
    Just chamfer the sharp edges
    Thomson is the best stem going IMHO, but they do have sharp edges. I've had two very good shops tell me that I should round off the sharp edges where the bar meets the stem, especially the outer edge where flexing of the bar could push it against it. It's a good thing to do with brake levers too. I have done it three times now, once with emery cloth and twice with a dremel.
    Oh, I also like to use a good torque wrench on most fasteners, especially when carbon parts are involved.
    Two Wheeled and Too Big
    King Pin
    Reputation: xrmattaz's Avatar
    Good job! Sharp edges.
    I just learned second hand from a very good buddy of mine that a certain well respected framebuilder recommends a different manufacturer of stems and seatposts, or suggests smoothing out the sharp edges a bit.
    I've heard tales of a Thommy seatpost eating right through the rails of a seat??
    Anyway, I'm checking mine, as I only use Thomson products in those two critical areas.
    Medium?
    Reputation: Fast Eddy's Avatar
    I just took mine apart
    after a few years. The 26" bar has a very slight indentation from the inside of the stem plate, but nothing on the outside where you would expect it from flex. I'm 190 lbs.
    I used to have a 24" bar in the same stem, and I checked it out too. That one shows four slight indentations on the front side from the stem plate. It seems like I used it for a shorter period of time too. Hmmm. Clamped too tight perhaps.
    In any case, I wouldn't hesitate to use either bar in a Thomson Stem, new or as they are now.
    JJT
    JJT is offline
    Reputation: JJT's Avatar
    I've been riding this combo seriously for 1.5 year know. I will get a new bar (same type) soon just to for my own state of mind, but untill now no problems and no sign of wear. I just removed the grips last weekend and saw some air bubbles under the coating beneath it. Anyone saw this phenomenon(???)?
    JJ
    And He was Not
    Reputation: Enoch's Avatar
    2 for me
    I have had 2 faceplates crack. Thomsom said 90% of the cracked faceplates were on Eastom CF bars. I was informed the newer faceplates were redesigned , but there still were a few of those that cracked also. Overtightenening can contribute to the cracked plate, but it was not the only factor. Thomson said it has something to do with the shape of the Easton carbon bars, it seems that they are not radius the same as the faceplates.
    Reputation: msiddens's Avatar
    Running the combo for 2 plus years and all smiles. My fav stem/bars hands down. Oh yes, for gods sake use a torque wrench!
    MS
    Click That Sh*t
    Don't think we didn't notice your bike,
    Quote Originally Posted by JJT
    JJ
    again.
    Damn that thing is so nice, it hurts the eyes,
    you should devote another thread to that machine.
    JJT
    JJT is offline
    Ha ha, thanks!! I'm still in love it myself and love just to look at it! I just changed wheels and brakes, so I will show it in a new thread, always good to hear other people like your bike.
    JJ
    Recovering Weight Weenie
    Reputation: Padre's Avatar
    Mines an 03 stem with carbon bars and I'm "not dead yet."
    Hmmmm...maybe my God-given torque-wrench is super accurate?
  1. Good "silver" riser bars..
    By FoShizzle in forum Turner
    Last Post: 03-21-2005, 03:26 PM
  2. Thomson factory tour (pics)
    By Al. in forum Riding Passion and Stories
    Last Post: 01-19-2005, 08:33 AM
  3. Thomson X4 users: bar-clamp weirdness?
    By tscheezy in forum Turner
    Last Post: 01-01-2005, 04:43 AM
  4. Replies: 0
    Last Post: 11-16-2004, 02:24 PM
  5. Easton carbon bars and bar ends
    By Scottay5150 in forum Colorado - Front Range
    Last Post: 08-15-2004, 06:42 PM
