Can I conver 9-speed rear wheel to single-speed?- Mtbr.com
Results 1 to 13 of 13
    Hello:
    I can get hold of a good quality 9-speed rear wheel.
    Can I remove the black plastic-like covering on the freehub and fit a single-speed sprocket there?
    The picture is at Sheldon Brown's Bicycle Glossary Ca--Ce and the direct link for the picture is
    Thanks for your help.
    Dirty South Underdog
    Reputation: Andrea138's Avatar
    You can use it as a SS wheel by using spacers, a SS cog, and a lockring
    Brickhouse Blog (most known unknown)
    Just Riding Along- best internet radio show on Mountain Bike Radio
    Jan 2009
    there should be a good explanation of how to do this in the FAQ section link at the top-right of this page.
    No. You cannot run a freewheel on a cassette body. As posted above though, you can use cassette spacers and a single speed cog to run your geared wheel as a singlespeed.
    Thanks guys--I did read the FAQ before posting.
    Th question is "Can I remove the black plastic-like covering on the freehub and then fit a single-speed sprocket (not free-wheel) there"
    Reputation: boomn's Avatar
    You don't need to remove anything. Just get a singlespeed cog with splines to fit on the freehub, like this. There are lots of SS freehub cogs in a wide range of prices. Any local bike shop or online shop should have some.
    The freehub body is made of either steel, aluminum, or titanium and the outside shell is not removable on its own. It is a structural part that holds the bearings and parts of the ratcheting engagement mechanism (details of the design vary between different hubs)
    Ovaries on the Outside
    Reputation: umarth's Avatar
    It will look like this (yes is the answer)
    Jan 2009
    Just get the spacers like umarth says and run a SS cog. Just make sure to match up the correct chain size - 1/32" or 1/8" etc. If you are running a crank that takes a 1/32" chain then you will need a SS cog that matches up to a 1/32" chain.
    "...quit hitting me with your hammer"
    http://tricountymtb.org/
    Niner EMD 1x10 ~ Niner SIR9 SS ~ Cannondale Scalpel Si
    Reputation: ianick's Avatar
    Quote Originally Posted by anga View Post
    No. Without the freehub your hub would look something like this:
    Quote Originally Posted by AGrant View Post
    As Boomn said. And about four others. It is a 3/32(ish) by the way.
    Quote Originally Posted by ianick View Post
    Thanks--got it!!
    So, the free wheel mechanism is inside the splined part.
    Thanks--got it!!
    Yes. Newer hubs have the free wheel mechanism inside the freehub body. The cassette slides on to the freehub body. This design is (supposed to be) simpler and cheaper to replace than a free wheel and cassette all in one.
  1. Replies: 0
    Last Post: 01-12-2010, 10:37 PM
  2. Single speed coaster brake rear wheel
    By Monkey_Man in forum Bike and Frame discussion
    Last Post: 02-26-2009, 10:49 PM
  3. single speed rear wheel ques
    By gmx in forum Singlespeed
    Last Post: 01-20-2009, 02:39 PM
  4. Road single speed campy rear wheel
    By beerski in forum Singlespeed
    Last Post: 12-09-2008, 09:18 PM
  5. SIngle Speed Rear Hub or Single Speed Conversion
    By cmil1 in forum Singlespeed
    Last Post: 02-13-2007, 03:09 PM
