Can this fork be saved? (x-post suspension)- Mtbr.com
Results 1 to 3 of 3
    AOK
    AOK is offline
    Reputation: AOK's Avatar
    I have a '99 Z2 BAM that I was considering using on my new SS ride in the event I get tired of the rigid fork.
    I have two protential issues - The fork needs a new steerer. The old one was damaged. I have the bolt-in type crown. Does anyone know where I can get a new steerer, and is replacing it a safe thing to do? I am assuming that the bolt-in crown allows me to safely seat a new one in there, but wanted to check.
    The 2nd issue is that I will be running disc brakes. Is the mount on the '99 fork compatible with today's brakes? It looks like the bolt spacing is the same, but the mount looks like it would put the caliber at a funny angle to the rotor (see pics). Will it work? If not, is there an adapter that I could use?
    player hater
    Reputation: VoltesV's Avatar
    Don't know...but I'll bet a quick call/email to 'zoke will tell you.
    Reputation: Brandon's Avatar
    Quote Originally Posted by VoltesV
    Yes you can replace the steerer yourself, I had a '99 Z3 that I replaced the steerer on, I just ordered it through my LBS (I think it was about $40) There are adapters to use those tabs with IS brake calipers or post-mount calipers but you migh have to run a larger rotor (185mm instead of 160mm) to use them.
  1. Feeling Inventive? The electric suspension fork
    By old_dude in forum General Discussion
    Last Post: 01-18-2012, 04:07 PM
  2. 24" suspension fork
    By mjparadise in forum Shocks and Suspension
    Last Post: 07-21-2008, 07:41 PM
  3. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  4. Replies: 6
    Last Post: 12-23-2004, 06:38 PM
  5. Replies: 5
    Last Post: 10-11-2004, 05:44 PM
