Can anyone recommend the Blackspire Mono Veloce Chainring?- Mtbr.com
Results 1 to 19 of 19
    I ran a search on the Blackspire Mono Veloce Chainring but wasn't able to turn up much. Anyone running them? How do you like it? Any issues? I'm thinking the 104BCD 4-ARM, 32T, No Ramps.
    Thanks in advance.
    You know, for kids
    Reputation: madcap's Avatar
    been running one for months now with no issues
    disclaimer: I sell and repair bicycles
    Space for rent...
    Reputation: SSteve F's Avatar
    Running them for 2 years....like them a lot!
    It's only pain......
    Bored
    Reputation: bigwheelboy_490's Avatar
    Jan 2003
    had one since March. Has held up very well.
    MTBR is serious stuff.
    You never get better until you get out of your comfort zone.
    HIYAH
    Reputation: heeler's Avatar
    Have had a few and have had no problems...wear about the same rate as any aluminum ring, a little faster once you wear the fancy coating off. I usually get them becuase they can be had cheap and have consisent quality.
    TTHHHHHHHHHPPPPPPPPPTTTTTTTTTTTTTTT
    Thanks for the help.
    E !
    E ! is offline
    Reputation: E !'s Avatar
    Jan 2005
    Yup
    Good stuff for the money.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    works great!
    Reputation: combatkimura's Avatar
    Works very well. I have a 36t that is in very good condition lying around pm me if you're interested.
    FMTCD
    Running a 36 and digging it for the price.
    Keep your friends close. Keep your enemies closer.
    ost
    ost is offline
    Oct 2007
    me too!!! i love it. looks good, cheap and hasn't given any trouble since new
    What crank is that in OST's picture? It nice
    Reputation: boomn's Avatar
    Quote Originally Posted by invariant
    That is a cut and polished XTR (older version)
    ost
    ost is offline
    Oct 2007
    M960 XTR, like boomn said, cut and polished, but also a reasonable amount of reshaping around the 4 arms.
    Just an update on the Mono Veloce. it now has 17 months of use and still no issues. the black coating has worn off around the teeth, so i will be watching it more closely for accelerated wear.
    if you're not breaking stuff, you're not going faster
    I win.
    Reputation: Popper252's Avatar
    I run mine in a 1x9 setup. I put a good 2000 miles on it before it was time to replace it with another. Due to the whacky chain lines you can get when running a 1x9 it probably wore out faster than usual. With a properly set up single speed I'm assuming it would last a bit longer.
    09 Giant Anthem X3
    07 IBEX Trophy Comp X7
    Reputation: CoffeeBean's Avatar
    Good job!
    have a Blackspire Mono Veloce 34t and a 36t...both hold up great...hundreds of miles and not a whimper...excellent value for the money...
    now Niner Cogs are a different story...all bling and thats about it...
    Be Who You Are and Say What You Feel Because Those Who Mind Don't Matter and Those Who Matter Don't Mind...Dr Seuss.
    Probably too late, but my $0.02
    Just pulled my 32T Blackspire off my 1x9 after a year and a half (~1500 miles all off road) and apart from the dirt it looks pretty much new. There's almost no wear at all on it. No finning, to side-wear, nothing. I'm impressed.
    I only pulled it off because I'm replacing it with a 34T. I'm going to try the e13 guidering because I got a deal on it and it's red, but a part of me is wondering if I should just go with the Blackspire again.
    I like turtles
    Reputation: TiGeo's Avatar
    Thats what I run; a 32T non-ramped 5-bolt (94mm) - so far so good. Its a chainring, not much to screw up. Its aluminum so it will wear out eventually.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro AF
    Expert Crasher
    Reputation: GreenLightGo's Avatar
    I swear by the Mono Veloce. Awesome rings for the SS.
    Happiness depends more on the inward disposition of mind than on outward circumstances. Benjamin Franklin
