Campagnolo 144 mm BCD 5 arms chainring- Mtbr.com
Results 1 to 12 of 12
    I bought a NOS Campagnolo record track crankset with a 1/8" 49T chainring to be used with my single speed.
    Questions:
    1. What is the chainline?
    2. I would prefer a 3/32" drive train, can I ask a machine shop to turn the existing 1/8" chainring into a 3/32"? what special precautions, if any, should I take during turning?
    3. Where can I buy 144 mm BCD 5 arms 3/32" chainring in smaller sizes? Any aftermarket manufacturers?
    4. Failing which I am considering buying the FSA track chainring and drill 5 144 mm BCD holes, has anyone done that? Is there a good method to ensure good accuracy to avoid off-center since I have little access to complex machineries.
    Thanks.
    Apr 2005
    Quote Originally Posted by wensiaw@pacific.net.sg
    Questions:
    track is pretty commonly 42.5mm (120mm rear)
    they definitely make them, but actual track stuff isn't cheap since there's less demand. (http://www.businesscycles.com/trcomp.htm#chainrings)
    hmmm... i think the trick is finding an original ring that has enough material to drill.
    Reputation: shiggy's Avatar
    Dec 1998
    Questions:
    Thanks.
    1. Use the spindle length you need to get the ring to line up with your cog. The latter will vary with the frame/hub..
    2. Just use a nice 1/8" chain. They work fine with 3/32 cogs. I like the Wippermann Whitestar (108?).
    3. Salsa (and FSA) offers track rings. Looks like 47t is as small as they go.
    4. Why would you need to drill out the FSA 144 BCD rings to fit your Campy 144 BCD crank?
    mtbtires.com
    Retro Grouch
    Reputation: aka brad's Avatar
    Questions:
    Thanks.
    Sheldon Brown is selling 42T for $89.
    http://sheldonbrown.com/harris/chainrings/144.html
    There also a 41 on ebay.
    http://cgi.ebay.com/CAMPAGNOLO-144-B...QQcmdZViewItem
    Brad
    Just one more rep and I get the toaster!
    Retro Grouch
    Otoh..
    Do you really want to use this Vintage Campy crank for your SS project? If your taking this thing off road, it may not hold up as well as a more contemporary crank. Also, if you do use this crank, at some point you will need to replace the chainring again. By that time it will probably be much harder to find and will be more expensive. Unless you are really big on vintage parts like yours truly, you could probably get a good prive for it on Ebay and use the money to buy something more up to the job..
    Brad
    Apr 2005
    Quote Originally Posted by aka brad
    nevermind the crank, 'nice' square taper bottom brackets are getting a little harder to find. if you don't care about the taper you can use the cheaper shimano ones, but other than that there is phil wood and actual track ones (which usually aren't sealed in any way because trackies don't want the drag :-).
    Retro Grouch
    Quote Originally Posted by neutered
    And while we're on the subject of BB, remember than Campy uses the ISO standard, which is different than Shimano's JIS. They usually can play together, but they are not the same and conflicts do arise. To be safe he would need to stay with ISO which would limit him further.
    Brad
    Retro Grouch
    Questions:
    Thanks.
    Hey I found some Salsa 42T rings on Speedgoat; $20 if your interested.
    Brad
    Thank you all!
    *Hotter than Hell*
    Aug 2005
    Campy
    111mm BB=42.5mm chainline for your Campy
    http://www.businesscycles.com/tr-refspec.htm#chainline
    PROFESSIONAL THREAD KILLER!
    Quote Originally Posted by FoShizzle
    Maybe I will just start hanging out in the "Recycle Bin" forum.
    Retro Grouch
    Brad
    Never mind, it was an old listing. Although they said they were in stock, the reality is Salsa probably haven't made these for years. Damn, they got me again
    But, I did find some more here @ Loose Screws for $37-38.
    http://www.loosescrews.com/index.cgi...d=359235422430
    Brad
    Look at the time!
    Reputation: lelebebbel's Avatar
    Jan 2005
    if this thing goes on a track frame, and you want the 42.5mm chainline, the campagnolo centaur BB (111mm ISO) is the one to get.
    However, if you want to mount the crank on an average road frame, things are going to be tight since the crank is really, really narrow ("Q-factor" is about 130mm). It might hit the chainstays and you'll need a longer BB, which is hard to find with ISO tapers.
    Don't even think of mounting this on a mtb frame, no way.
    wanted: Cannondale Lefty w/ V-brake studs
