Are cabon bars to flexy for a SS use?- Mtbr.com
Results 1 to 12 of 12
    Reputation: dazzat3's Avatar
    I'm Looking at ways to reduce my SS weight and was toying with the idea of fitting a carbon riser bar but I've got this gut feeling that it may be to flexable...Has any body had experience with carbon riser bars on their single speed?
    Single Speed Junkie
    Reputation: crux's Avatar
    Quote Originally Posted by dazzat3
    Pretty much thats all I have used on my bikes for years and never an issue. Reason I switched out was not for weight, but my hands would go numb after a few hours in the saddle. The carbon dampened the vibration just right soI dont have to worry about it.
    Super Moderator SuperModerator
    Reputation: driver bob's Avatar
    Carbon bar on my rigid SS and I've never noticed any flex.
    Truvativ Noir WC, lo-rise.
    Birdman aka JMJ
    Reputation: Birdman's Avatar
    Both my SS bikes (1 ti rigid, 1 steel hardtail) have carbon riser bars. I don't find them flexy enough to be noticeable.
    Good weight reduction with a much wider grip. ++ for me.
    JMJ
    Reputation: Andy R's Avatar
    Nov 2008
    I'm using Easton MonkeyLite bars (25.4mm) and I've never noticed anything that you'd call flex.
    Reputation: smaxor's Avatar
    Dec 2004
    I use syncros bulk carbon and they are very stiff but great dampening qualities
    Reputation: Minimalist's Avatar
    I use the Performance Forte bar on a rigid bike with no issues.
    Reputation: cruso414's Avatar
    syntace vector lowrise with 12degree sweep, 680mm width. Excellent very stiff bars.
    Mtbr Forum Sponsor - Homebrewed Components
    think you got your answer already, but yea, i know some big stong dudes riding carbon bars on their SS's and no problems.
    V-Shaped Rut
    Reputation: big_slacker's Avatar
    Quote Originally Posted by ISuckAtRiding
    I can pull like this, but for some reason I just can't flex my carbon bars. Don't worry OP, they're plenty strong and don't flex even if you yank on 'em.
    Reputation: metrotuned's Avatar
    Just had a convo with an Easton rep this week about this very topic. Apparently they test the carbon bars with even heavier weights than their aluminum for flex and it also requires more weight to break the carbon versus aluminum.
    Creative Producer, Will of the Sun, Platform Pedal Shootout 1M+ views WoS
    But what about the companies out there making the alloy/carbon mix. Seem to be cheaper, but isnt it still aluminum at the end of the day?
    Carbon Cycles is one example, "MatriX is the manufacture process for melding aluminum or alloy with carbon fiber. It allows our components to take advantage of the strengths of both materials. Carbon fiber is light and strong and alloy is heavy but flexible, so in matriX we get the best of both material's properties, at $65."
    Just wondering.
