Building Single Speed with Horizontal Dropout- Mtbr.com
Results 1 to 8 of 8
    May 2016
    I have a horizontal dropout that I want to make single speed. I am trying to avoid using a chain tensioner. I found a gear ratio very close to perfect and according to eehouse (great ss calculator) it is the closest I will get. I know about half links, eno hubs, and every other way to make it closer to fitting perfect. I don't want to pay for eno hub and I have seen a few forums that said you can file the axle or dropout. I think this will work but not exactly sure how to file it. Can someone please write a detailed description on how to do this or link me to a page that will allow it. Thanks.
    Also I would rather file the axel not the dropout because I can get a new axle but not a new bike but if filing the dropout is more ideal than I can do that as well.
    Downcountry AF
    Oct 2013
    with a proper hub you should not have to file anything. just get a bolt on hub from Surly or Hope, or even a QR hub with tug nuts would work just fine. example: i recently purchased a Surly Krampus that has horizontal drops. it came with a standard Shimano QR. no problem so far.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    The whole point of horizontal drop outs is that they should work with single speed. Sure you're not thinking of vertical drop outs?
    Jan 2009
    read this and then re-think what you are asking- Singlespeed Bicycle Conversions
    May 2016
    Sorry I am an Idiot I meant vertical dropout. I had horizontal dropouts on my mind and typed that
    Downcountry AF
    Oct 2013
    still no need to file anything. get yourself a tensioner, that's what they're designed to do. if you really can't stand the thought of one for some odd reason, get yourself a SS frame.
    the perfect gear will only last as long as your chain doesn't stretch, which for me is exactly 1/2 of the first ride on a new chain. so you will have wasted a lot of time and energy for a setup that is unlikely to work long term.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Jan 2009
    if you don't like the look and feel of a hanger-mounted tensioner, look into a Blackspire Stinger.
    Reputation: Velobike's Avatar
    Magic Ratio is the answer, and usually possible without mutilating the bike.
    It just requires the right combination of cogs and chainwheel.
    There's nothing wrong with running a singlespeed chain a bit slack, provided you are using:
    1. singlespeed chainrings and cogs with taller teeth than derailleur gears. (Derailleur gears are designed to allow the chain to slip off easily - a bad thing for SS)
    2. singlespeed chain (Derailleur chains are designed to flex sideways easily to slip off the cogs - again a bad thing for an SS)
    3. straight chainline
    Sometimes if you are close to getting it to fit, using a slightly worn chain will do the job.
    However, it really is much simpler to just get a singlespeed frame - eBay your old one and put that towards a proper SS frame. Good frames can be bought new relatively cheap from On-One or Surly, so secondhand they are a screaming bargain.
    Latitude: 5736' Highlands, Scotland
  1. Replies: 5
    Last Post: 04-12-2016, 08:15 PM
  2. Building a new single speed, what frame?
    By frontier2k1 in forum Singlespeed
    Last Post: 12-03-2012, 02:23 PM
  3. Horizontal dropout and derailleurs.
    By kikoraa in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-09-2012, 04:57 PM
  4. KM horizontal dropout problems
    By prattcm in forum Surly
    Last Post: 04-20-2012, 02:53 PM
  5. Replacement Horizontal Dropout on 08 Stumpy?
    By g-wiz in forum Specialized
    Last Post: 01-28-2011, 08:53 AM
