building alpine wheel with WI Eno and 18t trials!!- Mtbr.com
Results 1 to 7 of 7
    (he thinks he can)
    I'm starting to build a rear wheel for my SS f4!! it's going to have a WI eric's eccentric ENO rear hub with a WI trials 18t laced onto a Stan's Alpine rim!! Going to be about 2lbs of buttery smooth SS power!!
    Got the Trials 18t and the rest is on it's way!
    Attached Thumbnails Attached Thumbnails building alpine wheel with WI Eno and 18t trials!!-23463_487767450397_682405397_10927990_8023755_n.jpg
    building alpine wheel with WI Eno and 18t trials!!-23463_487767465397_682405397_10927991_2101374_n.jpg
    08 SS c'dale f4
    07 Prophet
    10 Yeti DJ
    Yeti Arc-x
    11 Yeti asr5-c
    ..and they place nice together!
    (he thinks he can)
    so trying to figure out what spoke length to use..using various calculator's i'm getting 255 or 259 ..confused.. any expert out there have any advice to set me straight
    ERD = 536
    center to flange 32
    flange diameter= 60
    08 SS c'dale f4
    07 Prophet
    10 Yeti DJ
    Yeti Arc-x
    11 Yeti asr5-c
    Reputation: tdee's Avatar
    Nice
    I have that hub on my Mamasita, And it works really well. I'm sure you will like it. Post some more pics when you get um.
    Dropbar SS Mamasita
    XTC Composite 29
    CruX
    Anthem X 29
    Unknown trials bike
    Reputation: scooter916's Avatar
    Quote Originally Posted by krismac
    ERD = 536
    center to flange 32
    flange diameter= 60
    with 32 hole 3 cross I got 259mm, I'm guessing both flanges and center to flange is the same?
    Quote Originally Posted by thefuzzbl
    aluminium has a tendency to fail when you need it most. i.e. you end up with a bad day.
    (he thinks he can)
    yea i got 259 using 3 different calculator's. I'll definitely post when it's all done
    08 SS c'dale f4
    07 Prophet
    10 Yeti DJ
    Yeti Arc-x
    11 Yeti asr5-c
    TallahasseeTrails
    Reputation: TallahasseeTrails's Avatar
    Recently switched from the std WI freewheel to their trials fw. Definitely quicker lockup when you need it.
    As a bonus it sounds like an irritated rattlesnake when you're coasting.
    http://www.tallahasseetrails.com/
    (he thinks he can)
    Quote Originally Posted by TallahasseeTrails
    I opted for the trials because i figured 30g's was worth difference because of the 2x in engagement points! This is pretty much a dream build for a SS rear wheel minus cx ray spokes! Going with DT swiss Rev. black with gold alloy nipples! love gold nipples
    08 SS c'dale f4
    07 Prophet
    10 Yeti DJ
    Yeti Arc-x
    11 Yeti asr5-c
