Broken derailluer used as chain tensioner??- Mtbr.com
    Can this broken derailluer be salvaged and used as a chain tensioner. If so please tell me how I would go about putting it to use.
    Newb trying first conversion w mtb.
    thanks for the help!!!
    Attached Thumbnails Attached Thumbnails Broken derailluer used as chain tensioner??-derailluer.jpg
    Is there a way to get that spring (pictured in your hand) back in securely? And if so will it hold tension enough to push the jockey wheels? if yes to both, then I know at least one way to make it work, you may need to buy longer limit screws however. (cheap from hardware store)
    no chain no gain.
    I don't think I can get it back in securely, that is the part that is broken. I was hoping to use it without the spring somehow. but now that I think about it I need the spring to create the tension... sorry for being such a newb.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Check with LBS see if they have spring out of broken derailuer .
