Boost Singlespeed Framesets?- Mtbr.com
Results 1 to 21 of 21
    Nov 2015
    So .. my google-fu is sucking. I'm trying to find a hardtail or softtail, boost spacing (12mm/15mm rear/front axles), singlespeed-awesome frameset (that may also run a x1 w/ cassette in the back if desired). Looking to do some SS monstercross, mtn biking and coffee shop runs.
    It looks like Pivot LES and Niner have offerings -- but I'm hesitating on the $2k+ pricetag for the frameset. Anybody else jumped in the boost bandwagon for SS frames?
    What's the point of boost anyways??? Oh yeah, they need to sell more bikes and that 135 spacing that has been around for 30 years would probably explode if it hit the trail today.
    Armature speller
    Sep 2004
    Quote Originally Posted by AKamp View Post
    To allow for fatter tyres.
    Nov 2007
    Trek Stache
    2018 Pole Machine
    2019 Norco Search XR Steel
    Downcountry AF
    Oct 2013
    +1 135/142 spacing. you will have many more options.
    is there some reason you think you need boost spacing? i don't know of any softtails currently available.
    the new Surly Karate Monkey fits the bill. it has gnot boost rear end which allows you to run any rear hub spacing you want.
    Edit: also check out Advocate Cycles Hayduke, and Spot Rocker
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Oct 2015
    salsa fargo
    Nov 2015
    Quote Originally Posted by *OneSpeed* View Post
    Understood on the spacing, but I have a set of Boost 29" XMC 1200/240s on my Fuel EX I want to be able to move back and forth.
    Nov 2015
    Looking at all the recommendations. Will summarize and add more as they come when I get a chance.
    Sent from my Nexus 6P using Tapatalk
    That makes more sense all of a sudden. I would simply build a new rear wheel and not let the wheels dictate what kind of bike I got. Keep the boost from end, that won't matter. Are the 240's true boost hubs or did they concert using end caps and a disk spacer
    Nov 2015
    They are true boost hubs f/r. I'm not committed to boost -- just trying to explore the options out there. If I were to build a second wheelset though, I'd like to build up a wider set that can run on my Fuel Ex and whatever this bike becomes (Monstercross, Hardtail SS and maybe geared). The Niner Air 9 RDO '17 frameset looks like a good match for what I'm thinking, but $2k :/.
    Reputation: grizzler's Avatar
    I ordered a Salsa Timberjack frame to build up SS 27.5+. Karate Monkey and Advocate Hayduke were close contenders.
    Reputation: OldHouseMan's Avatar
    The new Canfield Nimble9 has Boost spacing.
    The new Giant XTC+ is boosted, and even comes in a single speed build. All of the new XTC+ are single speed compatible as it has Trek Stache like dropouts.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    +1 for 135/142 rear spacing.
    I don't see the need to go wider than plus front and 2.25 or 2.4 rear on a single speed for my purposes at least (anywhere up to 90 mile SS rides on mixed buff single track/rocks/roots trails). I tend to sit my 50 year old bones on FS geared 29er for the more technical trails.
    【ツ】 eDub 【ツ】
    Feb 2005
    FYI, Boost hubs are not as wide as single speed specific 135/142x12 hubs. Sure the frames have wider dropouts but the stability of a dish-less stronger wheel is what makes the rear end less flex.
    Just food for thought since your considering a second wheel set.
    [COLOR="Black"]HARDMTNBIKER on Instagram
    Seven Sola SLX ENVE MTN SS
    Sir9 Carbon Niner SS
    #1gearallyear #Iridemtn
    LDC is ded,deth by trollz
    Nov 2015
    Quote Originally Posted by asmallsol View Post
    Are you getting one?
    Sent from my SM-G360P using Tapatalk
    Ill be out riding, youll still be trolling mtbr. Mtbr, where people who dont ride come to pretend they do.
    Moderator Moderator
    Reputation: 2melow's Avatar
    Quote Originally Posted by bolts View Post
    Here is a sweet Niner offering (not mine)..
    Attached Thumbnails Attached Thumbnails Boost Singlespeed Framesets?-2016-img_20161011_131559.jpg
    Front Range Forum Moderator
    Nov 2015
    Quote Originally Posted by 2melow View Post
    Yeah, that's the Niner I've been lusting over. Need to sell a couple older bikes first to rationalize it. I'm a bit hesitant to go the eccentric bottom bracket route vs sliding dropout (Stache, XTC+, others) though.
    Nov 2015
    I still haven't summarized the thread, but my LBS did order a Giant XTC+ (Lg) to check out. I'm in-between sizes (Lg/XL) and the specs have a rather short reach, so it's non-committal. I am oh-so-tempted though. Also emailed Lamere to see about there rigid boost fork... this could be seriously fun
    Reputation: bikeny's Avatar
    Jamis Dragonslayer
    Aug 2010
    Its not listed on the site, but I know that REEB makes boost single 27.5's (also fits a 29). Looking at picking up one my self.
  1. Niner RKT 9 with boost conversion and non-boost crank ?
    By philreske8614 in forum 29er Bikes
    Last Post: 08-30-2016, 10:57 PM
  2. Replies: 1
    Last Post: 04-27-2016, 06:25 PM
  3. Replies: 0
    Last Post: 04-26-2016, 04:03 AM
  4. Will older xx1 crankset with direct mount boost chainring work for boost
    By teamplayr in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 04-04-2016, 01:59 PM
  5. HOPE HUBS Pro 2 Evo/Pro 4 BOOST IS NOT BOOST!
    By yamaha46 in forum Wheels and Tires
    Last Post: 02-12-2016, 08:48 AM
Members who have read this thread: 11
