Boone Ti cogs / chainrings - 3/32 or 1/8th chains?- Mtbr.com
Results 1 to 10 of 10
    Reputation: ryan123's Avatar
    Do the boone cogs / chainrings run on 8/9 speed chains and SS / BMX or only one type?
    Idea! boone contact info.
    Bruce Boone
    BBoone5619@aol.com
    Boone Titanium Rings
    www.boonerings.com
    770-645-6488
    FTM
    FTM is offline
    Reputation: FTM's Avatar
    Sep 2004
    He generally makes them 3/32" which will run on both chains but you can request 1/8" thickness if that is what you want.
    FTM
    FTM is offline
    Sep 2004
    Quote Originally Posted by jomissa
    Bruce Boone
    BBoone5619@aol.com
    www.boonerings.com
    770-645-6488
    Actually, don't contact Bruce, he doesn't make rings for bikes anymore, just fingers.
    Contact Brett Brown (brett@browntechnologies.com) who makes the chainrings etc. under the Boone banner.
    I have tried contacting them numerous times, but have not received a reply...
    FTM
    FTM is offline
    Sep 2004
    Brett can be a little slow at times but he has always gotten back to me.
    Cheers. Thanks for that, hopefully will get reply soon!
    my knees hurt
    Reputation: singlespeedsycip's Avatar
    Jan 2005
    I've been running the wipperman 152 (whitestar) 1/8" chain on 3/32" rings for over 6000 miles with no problems at all....I don't know if its any stronger than a 3/32" chain but I broke two 3/32 in the past and the 1/8 is still holding up with no signs of stretch....
    Oh, running 32 x 18 boone cogs on my 29er....
    BELIEVE
    Imagine what you could achieve if you knew you would not fail.
    FTM
    FTM is offline
    Sep 2004
    Quote Originally Posted by singlespeedsycip
    Theoretically 3/32" chains are stronger, but neither chain should fail under normal riding conditions if it is of a good quality, properly installed and maintained and replaced when appropriate.
    Apr 2005
    Quote Originally Posted by FTM
    word. go 3/32 cog. you can use a 3/32 or 1/8 chain.
    with a 1/8 chain, you HAVE to use a 1/8 chain
