Are Boone cogs directional?- Mtbr.com
Results 1 to 11 of 11
    Feb 2005
    New question here. Are Boone cogs directional?
    I just had my 18T switched to a 17T and noticed the shop installed the 17T with the shinny surface facing in. My 18T had the shinny surface facing out. Does anyone have theirs installed facing in?
    Reputation: 29Colossus's Avatar
    content deleted as it could possibly offend someone some where some how some time
    Reputation: bikeny's Avatar
    Used to be directional
    The Boone cogs used to shark-fin shaped teeth that were directional and could only be run with the shiney side out. The tooth profile is now symetrical on all of their cogs, and the cog can be run either way. I'm not exactly sure when the change was made, but I believe like 2 years ago. People usually run them with the shiney side out until they are too worn, then flip them over. Keep in mind your chainline will move slightly when the cog is flipped.
    Mark
    highly visible
    Reputation: GlowBoy's Avatar
    Boone cogs are deliberately nondirectional so that you can flip them over and get double the life out of them. I've run mine both ways. I would be amazed if anyone could collapse a Boone cog by running it "backwards".
    "People like GloyBoy are deaf. They are partisan, intellectually lazy & usually very angry." -Jaybo
    34N 118W
    Reputation: Hollywood's Avatar
    shiney out
    Quote Originally Posted by GlowBoy
    I have an older 21t Boone and like bikeny said, the teeth are notched on one side, so they definitely look directional. Like a little pocket for the chain link to fit in. the opposite side is curved outward a bit. Not that the chain would ever slip off, but you wouldn't instinctively install it that way.
    Reputation: PeanutButterBreath's Avatar
    The design is certainly directional, I would contact Boone and ask before assuming anything.
    Most cogs are not directional. Your shop may not have thought about it.
    OK, I guess you could say the cog design is directional, but the tooth profile is not directional. It would be interesting to see what Boone has to say about running them backwards. I would be very surprised if someone could deform one of these cogs running it backwards. But, the only reason I could see to run them with the shiney side in is if they are worn out from running the other way, which takes quiet a while!
    Feb 2005
    Brett Boone says:
    The cogs were designed to have the polish surface facing towards the chainstay (outboard), the pattern is aesthetically designed to mount that way, but the teeth are not cut directional. It will actually function either way.
    Thanks,
    Brett
    highly visible
    Quote Originally Posted by PeanutButterBreath
    Certainly not making any assumptions: it has been discussed numerous times in the past on this board. The current design is directional only in form, not in function. FWIW, my "shop" was Boone direct, as with most other purchasers.
    Now I know
    And knowing is half the battle!
    I was referring to OP.
