Bike Build Up- Mtbr.com
Results 1 to 12 of 12
Thread: Bike Build Up
    Fat Boy Deluxe
    Reputation: DmofoT's Avatar
    Bike Build Up
    So I'm new to the whole ebb thing, but now I got a steel frame with an Al (I believe it's a Phil Wood style - two set screws?) ebb. I was wondering what you all use to grease it up before installation? Should I just use grease or do I need to use antiseize? I know, probably a dumb question, but I've never had an ebb before.
    <img src="http://athena.sas.upenn.edu/~david/albums/if/images/ebb.jpg" border=3>
    Also any other suggestions on what to use for cleaning parts before installing them? I remember reading the chain in the coffee can trick, but forget what people put in the can, just regular degreaser? But I'll also need to give the hubs, bb, cranks, and seatpost a good cleaning too.
    Thanks.
    DT
    Reputation: _K9_'s Avatar
    DT,
    I use regular grease on my EBB. I've also used antiseize and it worked OK too, but the grease seemed to last longer.
    I use Simple Green as my coffee can degreaser and my general spritz bottle cleaner. Works for me!
    Kevin
    Fat Boy Deluxe
    Quote Originally Posted by _K9_
    DT,
    Kevin
    Thanks Kevin, just what I was looking for. I was wondering about using Simple Green.
    Got one more question: if your doing a parts swap from one bike to another and you finally have all the parts swapped over, whats the best way to clean out the old frame, like inside the seat tube where there is extra grease and crud? Anyone got a method they use?
    DT
    Steamroller
    Reputation: Mattman's Avatar
    Chain - shaken not stirred
    I once read that if you use an empty 2 liter soda bottle with water and automatic dishwashing detergent it works well to clean an old grungy chain. You leave it a day or so and shake it a few times when you think about it. I have done it twice and it worked really good, but it was hard to get the chain out of the bottle, next time is used a juice bottle with a larger hole.
    Long handled bottle brushes get into seat tubes well. Simple green or Orange degreaser both work well for cleaning up bikes. Once they are clean, I'm a fan of Bike Lust to keep them pretty
    The best thing I seen for cleaning old and really grungy parts is an ultrasonic parts cleaner. Small ones are common in jewelry stores and dentists offices, big ones are used a lot for restoration of fire/smoke damaged stuff, and recently car restoration guys have started using them. These will probably find their way to bike shops. I'm looking for a car restoration place locally that has one. I'm hoping they will help me to clean up parts, wheels, frame, etc. from a '57 Schwinn Spitfire I'm cleaning up.
    Two Wheeled and Too Big
    A great way to clean parts like chains is in white gasoline. Probably don't want to use auto gas for flammability reasons, but soak something in white gas and brush it good and it'll be clean as new.
    Fat Boy Deluxe
    Quote Originally Posted by briwear
    Hmm...well I guess when your done scrubbing you could just light a match and burn off any excess. Easy clean up, ha.
    DT
    Quote Originally Posted by Mattman
    I use the elbow end of a spoke to hook the chain out.
    try driving your car less
    Reputation: jh_on_the_cape's Avatar
    Quote Originally Posted by DmofoT
    DT
    Hey, let's see the rest of that frame. Hemi orange IF? matching fork?
    Only boring people get bored.
    thread a string through one of the end links..be sure you have plenty of string before you dunk the chain..
    Fat Boy Deluxe
    Not quite done yet...
    Quote Originally Posted by jh_on_the_cape
    Well it's not quite finished yet, but close. Didn't know about the 29.4 seatpost size, but got a friend bringing one over. Has to be done by tonight as racing starts at midnight...
    But here's a shot of her showing some back...
    <img src="http://athena.sas.upenn.edu/~david/albums/if/images/backside.jpg" border=3>
    DT
    hand me the dice
    Reputation: TryAndStopMe's Avatar
    nice!
    DTeezie!
    yo, that jonx is hot. good luck on the build and at lodi tonight.
    your pal,
    chance
    "pain is only a pulse...if you just stop feeling it"
    DT
    thanks for the pic. i like the fade. you win!
  1. Help me build a budget full suspension bike
    By gimpless in forum Bike and Frame discussion
    Last Post: 02-15-2014, 03:48 PM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. build your own moutain bike?
    By jman0war in forum Beginner's Corner
    Last Post: 07-13-2004, 12:26 PM
  4. opinions
    By ScotchtapeLoser in forum General Discussion
    Last Post: 04-16-2004, 12:16 AM
  5. Updated - Happy bike theft story
    By Davetoo in forum Riding Passion
    Last Post: 03-24-2004, 03:08 AM
