Biggest cog with Paul Melvin?- Mtbr.com
Results 1 to 3 of 3
    miwuksurfer
    Guest
    I'm running an 18 tooth cog with my paul melvin with no problems right now, but the pulleys and the cog are relatively close. For the sake of hiking less, I would like to run a larger cog out back. Does anybody have any experience running a 19 or 20 tooth cog with their Melvin? Photos? Thanks.
    19 is about it.
    I had the same problem, and emailed Paul about it. The website says one thing, but I think even he disagreed. I am running a boone 19 tooth, and that's about it. You can try a 20, but it might be very close.
    Reputation: scooter916's Avatar
    you could always drop the front ring a tooth or two that will do the same thing
    Quote Originally Posted by thefuzzbl
    aluminium has a tendency to fail when you need it most. i.e. you end up with a bad day.
