Bianchi BUSS Seatpost Diameter ?- Mtbr.com
Results 1 to 6 of 6
    Reputation: Econoline's Avatar
    Anybody happen to know the seatpost diameter for the old UPS brown BUSS, maybe year 2000?
    I'm trying to run a Thomson 26.8 410mm with Salsa QR clamp and getting slippage problems. Seems like the Thomsom is slightly undersized or I'm running the wrong size for this frame. Thanks.
    Reputation: fiddlr40's Avatar
    27.2 is the correct size
    Quote Originally Posted by fiddlr40
    Too big. Maybe 27.0, or my frame is different than yours?
    Mine used a 27.2, and 27.2 has been the spec for all those bianchi SS for a while. 27.0 is an unusual size but it's possible. You could call the Bianchi USA folks at (510) 264-1001
    actually, the BuSS uses a 26.8mm seatpost. I have both a thomson and a dean for mine.
    you can look it up on either sheldonbrown or bianchi websites if you don't believe me.
    i find the salsa clamps very tempremental, you have to get the screw set "just so" to avoid slippage.
    i like the hope QR clamps better, myself, but YMMV
    Quote Originally Posted by biotruth
    Thanks for the info. Mine is definitely a 26.8mm also, as are the BUSS specs I found with a Google search. Don't know when the 27.2mm was introduced.
    I'll give the Hope QR a try with the Thomson post and see if that works. I upgraded to the Thomson from a Titec and the Titec never slipped with the Salsa QR, but it's a little short.
