Best way to cut shifter cabel stops off steel frame?- Mtbr.com
Results 1 to 12 of 12
    Dec 2009
    Have a steel frame that I plain to get powder coated. Whats the best way to remove? I guess I question if I just cut off with a small grinder wheel will it leave holes in my frame?
    Stokeless Asshat
    Reputation: jeff's Avatar
    If it's steel you should have no issues, as long as you have a light touch.
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    master blaster
    Reputation: veloreality's Avatar
    use a hacksaw and cut the top half to 3/4's off. use a large file for the rest. will take about 20 minutes longer but works out so much smoother. i did this on an old ss road bike.
    Quote Originally Posted by ISuckAtRiding View Post
    The dude is like 120lbs, tops lol he can run any tires he wants without issues, i'm sure.
    Reputation: farrisw1's Avatar
    Quote Originally Posted by jmlost
    If it does fill em in with some JB Weld, file it and sand it...good as new
    Put masking tape around it then use a dremel cut off blade to remove the bulk of it then put the grinding wheel on and finish the job. with a patience you should be able to go flush.
    dremel, earplugs, squirt bottle to cool the metal down between passes to make it easier on your blade (if you care), handfile or grinding wheel
    beer for when you're done.
    (if you cut into your frame, "yer doing it wrong moron")
    If steel is real then aluminium is supercallafragiliniun!
    Expert Crasher
    Reputation: GreenLightGo's Avatar
    I used a Dremel w/ cutoff wheel, then the drum sander to remove the remants.
    <a href="https://picasaweb.google.com/lh/photo/fqjc2YDY8Aqb2mCmT0JY9w?feat=embedwebsite"><img src="https://lh4.ggpht.com/_2W6rELw9q40/SbQR_3PYMCI/AAAAAAAAC5Y/ox11T3g3urA/s800/IMG_4161.JPG" /></a>
    <a href="https://picasaweb.google.com/lh/photo/w9rmQ0CtEq1XZ6dD1m3Pww?feat=embedwebsite"><img src="https://lh3.ggpht.com/_2W6rELw9q40/SbQSA79jDnI/AAAAAAAAC5g/Fn-p6wdKkcA/s800/IMG_4159.JPG" /></a>
    Followed up with a smooth frame and shiny black powdercoat.
    <a href="https://picasaweb.google.com/lh/photo/I9pm34NFuq_mSIjxG3GxgA?feat=embedwebsite"><img src="https://lh4.ggpht.com/_2W6rELw9q40/SbQRhwz0kcI/AAAAAAAAC5M/tPjy5Ylx4A4/s800/IMG_4504.JPG" /></a>
    Happiness depends more on the inward disposition of mind than on outward circumstances. Benjamin Franklin
    Out spokin'
    Dec 1999
    No, you will not leave holes.
    --Sparty
    disciplesofdirt.org
    Ovaries on the Outside
    Reputation: umarth's Avatar
    I don't really know why you would. I prefer options with my bikes, as it might become a commuter, a tourer, or another person's bike, down the road. I don't think unused braze ons look bad.
    Reputation: Big Pete's Avatar
    Good job!
    Quote Originally Posted by umarth
    Because it's his bike and yes they do look bad.
    Good job on doing what you feel looks best for your rig! I just love the way powder coat looks. It always looks wet.
    Quote Originally Posted by Big Pete
    Reading comprehension is always lacking.
    I Have Cookies
    Reputation: ae111black's Avatar
    Dec 2008
    yah same here but my SS frame didnt come with a deurilleur hanger so I'm not so inclined to keep them............
    The most important thing is what God thinks about it. He will have the final say. Joshua Stinebrink
    ____
    Kimo
