Best front tire for rigid?- Mtbr.com
Results 1 to 29 of 29
    I want to keep my rigid fork but its beating me up. What's the best, big front tire for shock absorbtion? I have a Bianchi SASS and am currently running a Kenda Kinetics 2.35. I am 200 lbs.
    That's gonna leave a mark
    Reputation: Upchuck's Avatar
    Quote Originally Posted by pjfinch
    I like the WTB Mutanoraptor 2.4" and the Kenda Nevegal 2.5".
    Fat fanatic.
    "Where the Fox Hat?" Endurance Team
    SoCal Colavita Road/MTB club
    bhc
    bhc is offline
    I have also enjoyed some rigid fork riding, but also needed to find some way to soften those bumbs, (42 years old). The 2.4 mutanoraptor at about 27-29 psi upfront seems to be my favorite, and have had no pinch flats on some 700 miles so far.
    Reputation: grawbass's Avatar
    The Kinetics 2.35 is a fairly small 2.35. If you're looking for something with more volume, decent grip and fairly low rolling resistance, I think the Kenda Cortez 2.4 is a good option.
    Other options would be Racing Ralph 2.4, Nobby Nic 2.4, Z-Max 2.35, Klein Deathgrip 2.35.
    Wanted: broken Titec 2 bolt seatpost, any size
    Reputation: dirtdirt223's Avatar
    Mar 2006
    i have a continental vertical pro 2.3 on my rigid and it does a good job.
    Psi
    So what kinds of air pressures are you guys running on these tires (with rigid forks)?
    bhc
    bhc is offline
    like I said earlier, keep it under 30
    But it all depends, are you trying to get there fast, or enjoy the scenery? When I take the rigid SS, its all about having fun, and enjoying the ride.
    I run mine around 30psi. And I'm running Stan's. And I weigh 180ish with gear. And I like walks in the park by the moonlight...
    Fat fanatic.
    Old School Steel!
    Reputation: zziggy13's Avatar
    I like my Schwalbe 2.4 Big Betty.
    uncompliant
    Reputation: JonathanB's Avatar
    Conti Diesel 2.5s have been working well for me for a while now. Looking for something different at the moment though (just for the hell of it).
    Reputation: burtondogs's Avatar
    I guess it depends on what kind of terrain you are riding.
    I have been reallt happy with the WTB Weirwolf 2.5.
    Works great on Northeast singletrack. (NY)
    I think that Greenfish had them for 19.95 or something.
    I have not tried the newer 2.55 LT version.
    Later
    Jim
    Quote Originally Posted by burtondogs
    Later
    Jim
    What terrain your riding makes a difference, I've never found a single do everything tire. I rode a Kinetics 2.3/Nevegal 2.1, they're the same size. I switched to Blue Groove 2.35 DTC and it made a huge difference in traction, with more shock absorbtion, and quite a bit biger. I like Weirwolfs too, but a 2.3 Weir is smaller than the BG. It's time to discover Shiggy for the real scoop on tires.
    Reputation: ionsmuse's Avatar
    I use a 2.5 Timberwolf race, usually around 25-8 psi. A fantastic tire, but a slow one. When/if I want a speedier fattie, I'll likely get on of the new Weirwolf 2.55 LT, looks very cool.
    Reputation: SprSonik's Avatar
    I am also @ 200 lbs, and run a Specialized Enduro Pro 2.2 on my SS (Marzocchi front fork) and this tire is very nice. Huge for a 2.2 (barely clears the fork), rolls nicely, and has a great tread pattern (for SoCal riding). They run in 2.2-2.4.
    Have at it!
    I am in the same place and am considering one of the following:
    1) IRC Trailbear
    2) WTB Mutanoraptors
    3) WTB Weirwolf
    4) WTB Motoraptor
    These are all 2.4-2.5" tires. I still wonder if I should just get a suspension fork and be done with it instead of buying a fat tire and then end up buying the fork later.
    I would second the timberwolf. A slow tire but it is cushy and it just eats up the corners. To bad there isn't a 29er version I'd be on it right now
    what the fu#k is the internet?
    bhc
    bhc is offline
    Quote Originally Posted by JZ19
    1) IRC Trailbear
    3) WTB Weirwolf
    4) WTB Motoraptor
    I have tried your first three up front, and the 2.4 mutano seems to be best. I ride in the dusty loose rocks of the southwest.
    those are Rollercams...
    Reputation: WTB-rider's Avatar
    Nokian Gazzaloddi 3.0 May not fit your fork however.
    Truly a wealth of useless information.
    http://blackdogadventureteam.blogspot.com/
    SUBLIM8er
    Reputation: Axis II's Avatar
    Conti Gravity Pro 2.3 w/Stans @ 25lbs. Best cornering front tire I have ever run. No washouts w/this on the front and great at eating up the bumps.
    Every man has inside himself a parasitic being who is acting not at all to his advantage.
    William S. Burroughs
    Reputation: upstatesspdr's Avatar
    Dec 2005
    Quote Originally Posted by bhc
    I'm in the northeast, lots of wet roots and rocks....not a good place for this tire imo
    It's pretty good for dry conditions but sketchy in the wet, plus packs up with mud easily.
    I'm having good luck with weirwolfs on the rigid bike, also the trailbear somebody mentioned is a good front tire.
    One of these days i will stuff a Panaracer FR in there if it fits, 2.4 or 2.5 whatever they are it 's a big tire
    Dec 2005
    Later
    Jim
    Jim,
    where are you located?
    i am in the Saratoga area
    I'm also happy with the Conti Deisal. Its really 2.4. I have the wire bead. I run it at 20 - 25 psi and it takes big hits without pinching. Rolls nice and floats well in sand.
    Reputation: slowrider's Avatar
    Hope a couple
    Yes I need a 12 step for tires but it's cheaper than a similar bike problem The 2.5 Diesel is closer to the stated width than most but works best as a rear tire in the southwest and is a fast roller and floats well in sand. I own Kenda Kinetics, blue groove and nevegal all sticky rubber 2.35 and they are more like 2.1s on Rhino lights and weigh about the same as the Diesel (740g) but roll slower; all the Kendas are better fronts than the Diesel. Mutano 2.4 is tall but more of a 2.1 in width but works on both ends, rolls well but isn't the most durable. Conti vert and gravity 2.3 are more 2.1s but the verts a good front decent rear while the gravity works best out back. My new favorite tire company is Schwalbe; 30g lighter than stated on all 4 tires I've bought. The Racing Ralph is fast wide cased and light at 510g for the 2.25 (actual 2.15) and 550g for the 2.4.(actual 2.25) The RR works best in back but still dosn't lean into corners all that well. The 2.35 King Jim Light and 2.4 Nobby Nic are both more like 2.25s but are very aggressive treads that weigh under 600g. The 2.35 KJL is a better front while the NN 2.4 works great on both ends, is as aggressive as the 2.35 Kendas but wider and 150g lighter while a fairly fast roller. The 2.4 Firepro FR is HUGE 2.5 plus, mostly tread and weighs 1080g (kevlar) and grip (and roll) like velcro. The Maxis 2.4 Advantage weighs 880 g rolls OK slips on slickrock but paddles through sand (while throwing it in you're face if up front) and measures just over 2.25 wide but is very tall.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    I have Conti Diesel (front)/Gravity (rear) on a hardtail. I am mainly happy with them, except there must be something better for wet rocks and roots.
    Category Winner
    Reputation: teamdicky's Avatar
    Diesel UST at 17.5 psi if I need to go fast.
    Gazzy 3.0 at 7.5 psi if I just need to run into things. The Gazzy is more fun than a barrel full of monkeys (Assuming the monkeys aren't dead. There's nothing fun about a barrel of dead monkeys.)
    WWW.TEAMDICKY.COM
    I get paid 3 every time I post on MTBR.
    Fall Branch Felon
    Reputation: toydeluxe's Avatar
    I've been pretty happy with my Mutano Raptor so far.............
    Alot of guys around here are running Weirwolfs, especially on the rear.
    "That which does not kill you, only makes you stronger"
    Haro WERX XCR
    Ibis Alibi
    Interloc Scandium Elite
    1) IRC Trailbear
    3) WTB Weirwolf
    4) WTB Motoraptor
    1: Haven't used.
    2: High volume, narrow for the size. Great dry all around tread, very fast.
    3: Fatter and lower profile. Folks seems to either love or hate their cornering ability.
    4: Great all around tire (if it's like the 2.24), especially on rocks and loose gravelly gunk.
    If you get a sussy you can always use the fat tire.
    Banned
    TT.
    TT. is offline
    wheeler
    I like the 2.4 mutanoraptor with stan's notubes at least 40mm of travel
    I Ride, I Know
