BB PF30 Help- Mtbr.com
Results 1 to 2 of 2
Thread: BB PF30 Help
    Reputation: Wcsting's Avatar
    BB PF30 Help
    I've ordered a new frame and it takes PF30. Is there any way I can use THIS BB with it? Is there an adapter?
    If that doesn't work what's a really high quality PF30 and crank solution?
    Reputation: Nater's Avatar
    This adaptor will get you where you want to go...
    SRAM/TruVativ PressFit 30 to 68/73mm English Thread Bottom Bracket Adaptor - AEBike.com
    Edit: It appears that this adaptor is to be used with a threaded external cup BB...not internal threaded BBs.
    I think you might be out of luck with running square taper in a PF30 frame.
    There are tons of cranks that will work though...basically any BB30 crankset or any 24mm spindle external bearing crankset will work. You just need to get the correct BB or adaptor BB combo.
