bash guard- Mtbr.com
Results 1 to 17 of 17
Thread: bash guard
    bash guard
    hey guys i am at a loss. i have scoured the internet looking for the perfect bash guard only to find out that its not made. i am hoping in the infinite wisdom of the people on the forums we can find a solution. i am looking for something like this design wise but in a four bolt hook up (104mm)
    http://www.chainreactioncycles.com/M...px?ModelID=241
    anodized or colored would be a plus but black will do also.
    stumpjumper 29 evo
    Jabberwocky
    Gt peace 9'r
    SE Lager
    is buachail foighneach me
    Reputation: sean salach's Avatar
    Did I catch a niner+?
    The style is nice looking but once it hits your ankle or leg its a different story. I use a BBG they're cheap, strong, light.
    pink
    I've always used that style and never had an issue with them cutting my leg.
    Here's another one available in 4 bolt:
    http://www.chainreactioncycles.com/M...x?ModelID=6246
    Reputation: illini's Avatar
    Dec 2009
    Its really hard to beat Ethirteen good strong polycarb looks good. I have the supercharger its light and strong.
    Is there a good bash guard for the SRAM 2x drivetrain? ie one that does not replace the outer ring as there are only two anyway on the SRAM.
    Mtbr Forum Sponsor - Homebrewed Components
    Quote Originally Posted by dipan
    I make one for the sram XX but it replaces the big ring. It's designed for use with one of my singlespeed rings. I cant think of how you'd put a bash ring on otherwise. The sram ring uses special bolts so it'd be a real pain to make something, and it wouldnt be very ideal unfortunately.
    Dec 2009
    Im such an idiot i didnt even read the link.
    @adelorenzo
    Reputation: anthony.delorenzo's Avatar
    Their website is down but Straitline makes a 4-bolt bash in that same style, comes in many colors.
    thanks guys! how much bigger is a salsa bash guards in comparison to a 32t ring. i usually don't run a bash guard think it looks better with out but if i could get a cool looking one maybe it would be different.
    ISAR what would it take to have a saw tooth bash cut?
    stumpjumper 29 evo
    Jabberwocky
    Gt peace 9'r
    SE Lager
    The Salsa, at 36T, will stick out I'm guessing about 1/2" further than your 32t ring. The second one I linked to will cover it perfectly.
    Quote Originally Posted by nickcarll
    I'd probably have to loose the lightening pockets, or the saw teeth would have to be pretty small. My rings are designed to be a little bigger than a 34t, so you can run up to that size.
    Plus size jersey model
    Reputation: bigworm520's Avatar
    Here is the one I just got for my Jabber http://www.universalcycles.com/shopp...s.php?id=21041
    Isuck just seen your stuff and it looks pretty nice def going to have to get one. That 2 piece rear cog looks rad.
    any good online shops where I can score an e. thirteen red bash guard?
    Well I just picked up the black e. Thirteen and lemme just say that the thing is a beast. I already smashed it on a nice rock and the dude infront of me thought I broke my rim! thing slides nice and easy over logs too so I couldnt be happier!!
