    Reputation: AteMrYeats's Avatar
    bar and stem question
    Let me get this straight: where the stem clamps the bar, the diameter is 1"; where the brake levers and shifter pods clamp the bar, the diameter is 7/8". Is this right?
    Mar 2005
    Good job! correct
    Quote Originally Posted by AteMrYeats
    You are correct sir, bar, to stem clamp is 1" or 25.4mm, grip/brake lever area is 7/8", there are also newer oversized bar stem combo's that are 31.8MM clamp area, but they still have 7/8" grip/lever area. almost all bmx bar and stem combo's are 7/8" from handle bar clamp area to grip area. And most road stuff is slightly larger at about 26mm, unless it's the new 31.8mm oversized like the mtn oversized.
    Reputation: shiggy's Avatar
    Dec 1998
    And road bars are ~23.8 mm in the grip/lever area.
    mtbtires.com
    Reputation: SeamusCA's Avatar
    Quote Originally Posted by single1x1
    This is something I've been wondering about: with a road bar being only .6mm larger clamping area, couldn't one fit a road bar in most MTB stems? Seems like a small enough difference that it should work.
    Jim
  1. Help! F99 stem + EC9O SL bar problem
    By Ty in forum Weight Weenies
    Last Post: 04-18-2007, 06:38 AM
  2. bar, stem length and front shock questions
    By baraant in forum Beginner's Corner
    Last Post: 04-19-2005, 11:19 AM
  3. steerer tube vs stem vs bar wt
    By drc in forum Weight Weenies
    Last Post: 07-23-2004, 08:03 PM
  4. Help!! Titec bar compatability question.
    By skatetokil in forum Tooltime
    Last Post: 05-30-2004, 07:20 PM
  5. Bar Ends -or- No Bar Ends
    By htims_nivek in forum Riding Passion and Stories
    Last Post: 03-22-2004, 10:15 AM
