Bar placement preference for your SS- Mtbr.com
Results 1 to 15 of 15
    Bars low and close or higher and farther forward?
    When I ride my SS, I sometimes feel like I rest too much on the bars, making me think a longer stem would be good to try. But then today I was riding my FS in a SS like gear and the lower and closer bars position felt kind of powerful and good.
    So what do you think works better and why?
    I like to try and maximize the benefit of the width and sweep of my riser, so I don't go too far forward or back where the sweep design would be compromised. I don't use the Mary bar or any alt. bar like that, although using one of those sounds interesting.
    My spoon is too big!
    Reputation: medieval's Avatar
    Oct 2007
    Low and close seems like it would feel cramped when standing.
    I kinda like low and long for my SS. My bike had a fairly tall riser bar with little sweep, and it just felt too high. The seated position was too upright, and the bike felt like a beach cruiser. I swapped it out for a Fleegle, which is a wide, flat bar with a 15* sweep. It made the handling much more predictable and stable.
    Beyond proper bike fitment though, it's really just personal preference.
    "If more of us valued food and cheer and song above hoarded gold, it would be a merrier world."
    J. R. R. Tolkien
    Out spokin'
    Dec 1999
    Absolutely, positively 100% personal preference. That said, I like my bar about the same height as my saddle, with the reach right where it feels best to me.
    Hope that helps a little.
    --Sparty
    disciplesofdirt.org
    SS or Die
    Reputation: -Muz R-'s Avatar
    --Sparty
    +1
    "Be the Gear..."
    Reputation: octotat's Avatar
    Bike set up is NOT personal preference! You shall all set your bikes up according to my instructions or you will all perish and burn in a lake of fire
    I got nothin'
    Reputation: hydrogeek's Avatar
    Feb 2006
    I set the height of the bar close the the seat, but I have a slightly shorter stem than I use on my FS and commuter bikes. The slightly shorter stem feels a little less squirrely to me on the trail than the longer reach over the front end with a long stem.
    I ride at ludicrous speed
    I use a 90mm stem with the bars at the same level or a bit lower than the seat. I like a decent amount of weight on the front wheel in the tight turns so i can lean forward and power through it.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    I typically orient my bars towards the front. When they are up there, I like them about saddle height because it is easier to climb and keep weight back.
    I like my bars to be comfortable when standing on a long out of the saddle climbs. This also gives me a pretty upright position when seated, which for me gives me more power. Make sure your on an incline when you check standing bar position.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    I have my bar just a little below the seat. If the bar is too far forward, it feels like it is hard to keep enough weight on the rear wheel when climbing out of the saddle.
    Reputation: Whyaduck's Avatar
    I like mine a little below my seat. Currently I've got a 90 mm stem with a 12 deg rise, but I think I might swap it for a 100 mm flat stem. I picked up the Race Face Next XC carbon bars (3/4" rise). Nice and wide, great damping, they're fantastic; highly recommended.
    I'm still not sure about these responses...
    Low and far reach?
    High and far reach?
    Low and close?
    High and close?
    Has anybody tried some combo of these to find the right setting for them? And if so what works and why?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    I set my bikes up the same , geared or s.s. It is completely dependent on rider preference , I do not buy into single speed position , it is just bike position . Just my take on things .
    Quote Originally Posted by AZ.MTNS
    Fair enough. But I suppose that means you never feel like you need to change your position much (or at least you body shifts are all comfortable and expected depending on the terrain). So you might be lucky.
