Results 1 to 19 of 19
    Axle sliding in dropout on brake side
    I've got a tensioner for my drive side, but nothing I've found will work to keep my non-drive side axle from moving towards the back of my horizontal dropouts. Do I just have a crappy skewer?
    All of the true things I'm about to tell you are shameless lies.
    The need for singlespeed
    Reputation: zaskaranddriver's Avatar
    If it's not an enclosed cam skewer, e.g. XT, then yes.
    Anyone know of an enclosed cam, 10mm skewer?
    Bro
    Bro is offline
    Content from my avatar
    Reputation: Bro's Avatar
    Dec 2010
    Quote Originally Posted by False View Post
    Anything from Shimano....
    Sometimes, I question the value of my content.
    meh... whatever
    Reputation: monogod's Avatar
    Feb 2006
    on my fixed monkey i've used both the salsa and xt skewers without a slip. the salsa is one gnarly skewer.
    "Knowledge is good." ~ Emil Faber
    Dec 2010
    Get XT...best thing I did for my SS. No more slippage
    Dinner for wolves
    Reputation: buddhak's Avatar
    Quote Originally Posted by sasquatch rides a SS View Post
    XT skewer and a driveside tensioner. That's all I've ever needed with surly horizontal dropouts for the past 4 years.
    Responds to gravity
    Bro
    Bro is offline
    Dec 2010
    Quote Originally Posted by buddhak View Post
    Tensioner with horizontal drops?
    Dinner for wolves
    Sorry Erik,
    I was referring to the horizontal "track ends" Surly uses on their 1x1 and KM.
    Responds to gravity
    Dinner for wolves
    But FWIW you can use tensioners on true horizontal drops that face forwards also.
    Responds to gravity
    surly inbred
    Reputation: TroutBum's Avatar
    I've been tension free with one tugnut on my Inbred. Get the XT skewer & don't be afraid to scuff up the dropouts with some sandpaper. Oh, and make sure it's tight. Stoopid tight.
    Quote Originally Posted by TroutBum View Post
    I've been tension free with one tugnut on my Inbred..
    Tugnutts make the world of difference, I use LX skewers (yes cheap LX skewers) and I have 0 slippage on my surly 1x1 frame.
    Friends don't let friends ride geared bikes
    Reputation: Flat Ark's Avatar
    Don't use the Crank Bros. 2 piece skewers! They are expensive/heavy and won't hold my rear axle in place for crap. I even took a pair of channel locks and tightened the non-lever side as tight as I could get it. Ultimately I ended up using a zip tie to secure my rear wheel to the frame.
    As far as I can tell XT skewers are not for 10mm thru-axles. They are 10x1, which would make me nervous going through my hub. I found some from DT Swiss, though.
    Let's ride
    Reputation: rensho's Avatar
    XT are the traditional 4mm shaft.
    DT 10mm RWS should do it. I love em.
    I've had bad luck with running only 1 tug, and a QR certainly always caused trouble for me on the brake side. The brake side sees high forces too.
    Reputation: boomn's Avatar
    Quote Originally Posted by erik1245 View Post
    it is definitely confusing, but "tensioner" is also the word most people use to describe an axle puller or axle tug or whatever ever some people call them
    openwound
    Reputation: voodoochild's Avatar
    I'm running a 10mm DT Swiss RWS on my bianchi SOK. Works a charm. I'm using it on a DT Swiss 240s. I mention this because I checked to see if I could run the same thing on a Hadley bolt-on rear hub but the 10mm skewer didn't fit that axle.
    -- let's ride
    Quote Originally Posted by voodoochild View Post
    Hadleys should convertible to 10mm thru bolt I thought? I've been using a Hadley 10mm aluminum thru-bolt in my DT 240 for a while and it worked great on m Inbred's track ens
    openwound
    It's not that the Hadley isn't convertible to 10mm, it's that the standard issue ss bolt-on axle inner diameter would not accommodate the 10mm RWS skewer. It was just a hair too small. I'm sure that if I got the 10mm axle it'd be money. The inner diameter of the standard issue bolt-on 240s will accommodate the 10mm axle. Sorry for the confusion.
    -- let's ride
  1. Which sliding dropout?
    By TheWoodsman in forum Frame Building
    Last Post: 09-12-2010, 11:23 AM
  2. Sliding/Slot Dropout Axle Placement
    By D1PHAM in forum 29er Bikes
    Last Post: 05-18-2009, 01:24 PM
  3. Sliding dropout technique?
    By fastale in forum Singlespeed
    Last Post: 02-26-2008, 07:23 AM
  4. Seven sliding dropout!
    By Go Kart Motzart in forum 29er Bikes
    Last Post: 11-14-2006, 12:56 PM
  5. Sliding Dropout Advice
    By zazen in forum Kona
    Last Post: 02-08-2006, 06:45 AM
