Axle to Crown Measurements- Mtbr.com
Results 1 to 6 of 6
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    New question here. Axle to Crown Measurements
    When measuring fork length, you measure from the center of the axle to the crown, but where on the crown? Is it to the crown race? I wonder because I just ordered a surly 1x1 fork, and got to measuring my old Marin rigid fork, and it seems to be about 16.1 inches(about 410 mm) from axle to the crown race. Am I just stupid, or did I just order a suspension corrected rigid fork for nothing?
    Shreddin the Cul de Sac
    Reputation: Burpee's Avatar
    Looks that way.
    Quote Originally Posted by 1 cog frog
    Surly 1x1 axle to crown is 413mm:
    http://www.surlybikes.com/forks.html
    What's wrong with the original Marin fork?
    Cancel the order.
    keep moving
    Reputation: shiggy's Avatar
    Dec 1998
    There was no "standard" for fork length before suspension. Forks could vary widely.
    mtbtires.com
    Mtn Biker Machinist
    Dec 2004
    Reasons why
    The Marin fork seemed to drop the front end significantly after changing from a Manitou SX-R 80mm, so I thought the surly would raise it back up. Plus the it doesn't have disc mounts, and I want to run a disc up front. My original question is still am I measuring right? I even compared the length of the Marin to a '98 Manitou that has 65mm travel, and to my '02 Skareb with 80mm, and it is definitely shorter than both. Can anyone clarify cuz I'm still confused?! thanks
    Dec 1998
    Put a screwdriver in the dropouts and measure from the driver to the fork crown race seat.
    mtbtires.com
    Don't forget to take fork sag into account when the fork is loaded with your weight on the bike. You want to compare the suspension fork axel to crown when it is sagged. And if you are going to run a FAT tire, take that into account too.
    Example: I replaced a Judy T2 80mm fork and 2.1" tire with a Surly 1x1 and a 2.7" tire. The result is the ride geometry of the bike is unchanged. The Surly 1x1 was a little shorter than the sagged Judy but the FAT tire resulted in a 27" wheel. The 1/2 inch of extra wheel radius compensated for the slightly shorter Surly axel to crown length
  1. axle to crown heights
    By FishMan473 in forum Shocks and Suspension
    Last Post: 12-13-2004, 09:09 AM
  2. Reba axle - crown height
    By Emilio in forum Shocks and Suspension
    Last Post: 11-05-2004, 03:11 AM
  3. Measuring axle to crown
    By Lemonhead in forum Shocks and Suspension
    Last Post: 04-02-2004, 05:30 AM
  4. Fox 125 RL Vanilla axle to crown height
    By dcinc0 in forum Shocks and Suspension
    Last Post: 03-31-2004, 10:13 AM
  5. 125mm fork axle to crown height measurements
    By hammerheadbikes in forum Shocks and Suspension
    Last Post: 02-04-2004, 09:47 PM
