Avid BB7 set-up help- Mtbr.com
Results 1 to 27 of 27
    Not strictly a SS issue but I know a lot of you guys use these brakes and I am fitting them to my SS.
    The installation instructions say that the rotor should not be centered in the caliper. My question is - which way should it be offset? The diagram seems to contradict itself. The enlarged view seems to show the rotor closer to the main body of the caliper but the actual picture shows it closer to the inboard (wheel side) pad.
    Maybe it's just me being dumb but I can't decide which way to offset it. Any BB7 experts out there?
    Cheers.
    Reputation: amblake50's Avatar
    Nov 2008
    check out sram tech on youtube they have great set up videos.
    Excellent idea! Thanks.
    i have used this "how-to" from Park Tools: http://www.parktool.com/repair/readhowto.asp?id=124
    WWYD?
    Reputation: johnnyb's Avatar
    Quote Originally Posted by nomad9
    Cheers.
    I've got them on all four of my mountain bikes.
    The illustration shows left side as the "outside" of your rotor/wheel and the right is the "inside" of the wheel. I'm not sure what the offset is for, but I usually get it near to that and adjust the pads as I'm looking over the rotor to make sure the "outside" pad doesn't flex the rotor too much when you use the lever.
    Reputation: veritechy's Avatar
    I think depending if it is closer or farther from the rotor you get a different "feel". Some of the guys in the "brakes" forum mentioned that in one config you get more modulation...
    Thanks for the help guys. I found some useful stuff on you tube that has answered my initial question.
    Cheers.
    Yups and make sure that the rotor does not flex too much or you'll get uneven wear on your brakepads. I did that accidentaly and now I have several pads wich are bare metal on the top and loads of pad material at the bottom.
    achiever
    Reputation: redwarrior's Avatar
    I find the "official" set up doesn't work well. The rotor flexes a lot and on a rigid fork, you get a ton more radial deflection/chatter. When the set up is opposite of what is recommended, everything works awesome. I have mine set up closer to the inboard pad and they work great.
    Super Moderator SuperModerator
    Reputation: driver bob's Avatar
    x 2 on redwarriors set up. I run the rotor closer to the fixed pad as well and the brakes work great.
    May 2005
    Regardless of what SRAM says,it seems obvious that you would try to get the rotor as close to the inboard pad as possible since that pad doesn't move. Otherwise you waste energy bending the rotor towards the pad. I can't think of any logical reason why you would want to do otherwise.
    Reputation: boomn's Avatar
    Quote Originally Posted by Thor29
    as already mentioned in this thread, the spacing of the inner pad changes the feel and modulation of the brake, and personal preference over these two things is a logical enough answer for me. Spacing the inboard pad further from the rotor gives the brake a softer feel through a slightly larger portion of the initial lever travel and makes the brake feel less grabby. Again, that is personal preference.
    dial both levers in until it's locked up, tighten the bolts holding the caliper to the fork/frame, then dial each side out until you get the feel you like.
    (redwarriors etc are right, it's the hot setup for power)
    If steel is real then aluminium is supercallafragiliniun!
    I will tighten each pad just to the point it starts rubbing, and then I'll back it off one click. This gives me the quickest engagement without any rubbing.
    Reputation: Singlespeed McGee's Avatar
    Not trying to hijack this thread, but while on the topic of BB7's mine howl like a dying rabbit. They're kind of new so it might just be that they're not broken in enough. By the way, it's only the front brake. Any other ideas why it howls?
    "So do me a favor. Find your bike, whatever kind of bike it is. And RIDE it." -Gary Fisher
    WWYD?
    Quote Originally Posted by Singlespeed McGee
    You might have two reasons for the howling:
    1. There is some contaminant like oil or grease on the rotor or pads. Rubbing alcohol or acetone will clean that up. If its on the pads, you probably will have to replace them.
    2. The pads are not set up right, they are not parallel to the rotor (adjust the mounting bolts to the Avid adaptor) or they are not set up evenly--exactly what this thread is about.
    There isn't a break-in period for these brakes other than a dozen pulls on the brake after you replace the pads.
    Reputation: Ze_Zaskar's Avatar
    Honestly?
    I just put the pads as close as possible to the rotor without rub. Best braking ever on my bike.
    About the noise, mine used to scream like a teenage girl on a slasher movie on the first 3 or 4 rides. How many miles do you have on yours?
    My spoon is too big!
    Reputation: medieval's Avatar
    Oct 2007
    The picture above is showing the spacing on the caliper, not the pads. The rotor is off-center towards the outside, to allow it to be deflected during use, without contacting the caliper.
    Pad spacing is more subjective. I like the inboard pad to be very close to the rotor, to give a good solid feel at the levers.
    "If more of us valued food and cheer and song above hoarded gold, it would be a merrier world."
    J. R. R. Tolkien
    2010 RockHopper Comp Disc
    Some of you are recommending aligning the rotor closer to the inboard side of the caliper, but why would that matter. The outboard pad will wear faster than the inboard, as it is doing the most work. So its alot more reasonable to keep the outboard pad as flexible/adjustable as possible. The brake is prone to allowing the outboard piston to hyperextend when dialed out to far.
    Whether the inboard pad is closer or further from its base position shouldn't really matter. As long as there is little rotor moment when the brake is engaged, both should offer similar performance. Its simply adjusting to see what will happen in the future. When the outboard pad wears a bit and you hyper extend it's piston you will simply need to readjust the calliper to compensate. That's the reason Avid tells you to do a 2/3 and 1/3 partition.
    Reputation: kbollox's Avatar
    try giving the rotor a good cleaning with disc brake cleaner.
    Reputation: Velobike's Avatar
    I have a couple of shims I use to get the clearances right. Just wind the adjusters down tight on them, fasten down the calliper, then loosen adjusters just enough to pull out the shims.
    Means I can set it exactly the same each time. (I know this could be done by counting the clicks too)
    Latitude: 5736' Highlands, Scotland
    Reputation: wickerman1's Avatar
    Skimmed through the posts, place the rotor closest to the inside( the non piston side.inside) of the caliper, that way the rotor wont flex much and have much better braking surface.
    nothing to see here
    Reputation: Stevob's Avatar
    More inboard wrt the caliper also gives clearance for the adjuster bolts on the caliper. They run very close to the rotor.
    I see hills.
    I want to climb them.
    There is obviosly a reason SRAM and Park both recommend keeping it closer to the outboard pad. Rotor movement can be controlled from the inboard pad, irregardless of where rotor actually is.
    I could see this being an issue with the BB5 where the fixed inside pad isn't adjustable, but is it really an issue with the BB7 so long as the rotor isn't rubbing anything and is parallel with the caliper?
    nothing to see here
    wouldn't think so
    I see hills.
    Have any of you noticed a difference in performance when switching from the stock rotor to a g2 or g3 rotor?
