Results 1 to 8 of 8
    Down South Yooper
    Reputation: Plum's Avatar
    Sep 2004
    Attn: Paul Disc Unit Users
    Hey all, got a query for you. Is the disc unit compatible with other hubs too, or just the paul WORD's? It's not clear to me what it's mounted to on the hub, is it a spacer bracket on the axle? Can I use it for, say, an XT disc rear?
    Thanks.
    Plum
    Reputation: shiggy's Avatar
    Dec 1998
    The Disk Unit threads onto the WORD axle in place of the "locknut" (not really a locknut). Not designed to be used on any other hub. I thought this, from the Tech section of the Paul site, was pretty clear
    IMPORTANT! Read this first:
    The Disk Unit will fit only the PAUL DiskWORD hub.
    mtbtires.com
    Down South Yooper
    Sep 2004
    Oh, yeah...
    Yeah, I didn't get that far, my bad. What do you do if you have a frame that will take a geared rear wheel, but only has the paul disc unit mount on the stay? Is it back to canti's?
    Plum
    Dec 1998
    Quote Originally Posted by Plum
    Plum
    I do not understand the question.
    mtbtires.com
    Down South Yooper
    Sep 2004
    For instance
    On a particular Kelly RoShamBo I'm eyeing, it has KM style, horizontal dropouts with a derailleur hanger. It also has only a PAUL disc unit mount on the stay, not an IS disc mount. If you were to run this frame geared, how would you mount the caliper?
    Plum
    Dec 1998
    I think Woodman has a gearie hub and axle disc mount combo.
    mtbtires.com
    Down South Yooper
    Sep 2004
    Thanks Shig
    A good lead, as always. Thanks.
    Plum
    Reputation: itsdoable's Avatar
    Plum
    You can probably use a Brake Therapy adapter too, and any BT compatible hub. With both the Woodman and BT, you'll need to modify the torque arm (shorten it) to fit the Kelly.
    Cheers,
    Tom
  1. Attn. Shiggy or Sch. Fat Albert users
    By rr in forum Wheels and Tires
    Last Post: 09-23-2004, 01:54 PM
  2. Paul Disc Unit ?
    By lanpope in forum Singlespeed
    Last Post: 07-20-2004, 03:07 PM
  3. paging all 04 xtr disc users..................
    By marco in forum Weight Weenies
    Last Post: 05-24-2004, 02:12 PM
  4. Attn: Time and Eggbeater users (non-wt.)
    By eric in forum Weight Weenies
    Last Post: 01-28-2004, 06:54 AM
