Attention Dirt Drop Users: help me!- Mtbr.com
Results 1 to 15 of 15
    giddy up!
    Reputation: donkey's Avatar
    Does anyone have a reccomended starting point for stem length and rise when using dirt drops? My situation is this....I have a surly KM that I am dying to try some dirt drops on. I am currently using a 120mm x 6 degree rise with a flat bar.
    Any idea what length and rise would be a good starting point based on the current bar/stem setup?
    Thanks for the help, Brian
    www.thepathbikeshop.com
    Recovering Weight Weenie
    Reputation: Padre's Avatar
    Step 1: Remove dirt drops.
    Step 2: Re-install riser or flat bars.
    Step 3: Re-install your regular stem
    Step 4: Go riding.
    Step 5: Keep the drops on the road bike.
    Hope that helps! =)
    giddy up!
    Hey...
    ....it's a spare bike, I'm just experimenting!
    We should put some drops on your "other" SS!
    Quote Originally Posted by Padre
    Step 4: Go riding.
    Hope that helps! =)
    Dude, that would be sick!
    I could compete w/ Shiggy as far as interesting rigs go!
    Let's do it! Dirt drops on the Bullit! We'll add some 300mm cranks too. I think the high BB of the Bullit will surely accomodate.
    giddy up!
    Dude...
    .....you're tall enough, go 305mm....the extra 5mm will really help out.
    Quote Originally Posted by donkey
    Yes, I've calculated a 16.0795% increase in expostulated cross-referenced and circumnavigated leverage. Plus my legs will make such a big circle that my feet will actually rise above the handle bars on the up stroke creating power heretofore unseen by mortals.
    Step 1.5
    Step 4: Go riding.
    Step 1.5: Send the Dirt Drops to me!
    No really, you probably should start with about a 150x30deg stem to get the hooks/drops up level with your flat bar position. With some trig you should be able to figure it out exactly if you can find the drop and reach of the DDs.
    OR, just scr*w it and send 'em to me.
    giddy up!
    Huh..
    ......don't I want to go with a shorter stem?
    Quote Originally Posted by 03bart
    Reputation: shiggy's Avatar
    Dec 1998
    Try a 130 x 40° or 110 x 40°. Nashbar has them on sale for $17 http://www.nashbar.com/profile.cfm?c...eid=&pagename=
    You may need some spacers under it.
    mtbtires.com
    giddy up!
    Thanks Shiggy...that helps...
    Am I correct in thinking that I want the drops to be at about the same height that a flat bar would be at?
    Quote Originally Posted by shiggy©®™
    flexiflyer
    Guest
    I wrote a good bit about this on the old board:
    flexiflyer
    Guest
    No, you don't. Read the links I've posted in this thread!
    MC
    giddy up!
    Excellent!
    Thanks for the links Matt, the last one in particular cleared up what I was thinking in regards to shorter/longer stems...It all makes sense now:-) I hope that I can find something tall/long enough to get this setup properly, I am dying to try these dirt dropd out! I'll post pics when I get a stem and see what ya'll think.
    Quote Originally Posted by flexiflyer
    MC
    all hail der Fuhrer Bush
    my Ibis LD stem
    measures about 17cm vertically from the top of the headset to the center of the bar clamp, with about an 8cm forward extension. the true test is whether you can do long rides whilst riding in the drops 100 percent of the time. set up "properly" you would never want to ride on the hoods, nor could you, because your brake levers are so low on the curve for comfy access in the drops that you can't get your hands on the hoods without reaching over the top of the bar. see pix of Jacquie Phelan's old Cunningham Indian for a good setup; and pix of Tomac the year he raced with drops for a bad setup. none of the stem dimensions mentioned in this thread sound high enough to me.
    Not a regular
    Here's a link to more info on off-road drop bar set-up. http://forums.mtbr.com/showthread.php?t=5119
  1. Replies: 7
    Last Post: 04-28-2004, 10:01 AM
  2. Pictures: sunset jumping, berms, super ghetto drop
    By ThoughtfulPirate in forum Downhill - Freeride
    Last Post: 04-04-2004, 03:37 PM
  3. Replies: 15
    Last Post: 03-20-2004, 03:39 PM
  4. Who rides dirt bikes?
    By dpdsurf in forum General Discussion
    Last Post: 03-15-2004, 08:27 PM
  5. dirt drops questions
    By colker1 in forum Vintage, Retro, Classic
    Last Post: 02-17-2004, 09:02 AM
