Anyone tried this SS from NYCBikes?- Mtbr.com
    Reputation: Mackie's Avatar
    http://www.nycbikes.com/item.php?item_id=409
    From their site:
    Uberurban Aluminum Alloy Frame, Cro-Moly Fork, Cane Creek Headset, Ritchey Comp Handlebar, Shimano Exage Levers, Alhonga Cantilever Brakes, CPI 34t Single Crank w/Bashguard, Zac 19/Quando Wheels, 16t Dicta Freewheel, Vee Rubber 700x38 Slicks.
    It's $350, the frame is 135mm spacing, and they claim that the tension is good using the "magic" combo of 34:16.
    I've been looking for a cheap, beatable drop bar 700c singlespeed, and this looks like it. But I worry about the "magic" gear. Anyone try one of these things? How good was the chain tesion?
    Thanks for any info.
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    I've not tried this bike, and I don't know if where you live is hilly, but that gear ratio is pretty low for a road commuter. And because it's a "magic ratio" on what I assume is a vert drop, you don't have much flexibility with gearing.
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    Reputation: pacman's Avatar
    How much will you ride it?
    Quote Originally Posted by Mackie
    As you put miles on a bike, the chain wear will remove the "magic". Plan to keep a stock of new chains.
    Steamroller
    Reputation: Mattman's Avatar
    Check out IRO cycles
    IRO is also in New York, they have a new SS cyclocross bike that I think is nicer than this one. It's called the Rob Roy and it costs a bit more but I think it's worth it for a chromoly frame and the sweet curved seat stays among other things.
    http://www.irocycle.com/id111.html
    Two Wheeled and Too Big
  1. Newbie needs help with SS setup
    By Little Willy in forum Singlespeed
    Last Post: 02-05-2005, 07:02 PM
  2. Emerging SS Perspective
    By waltaz in forum Arizona
    Last Post: 01-15-2005, 07:40 AM
  3. Singlespeed: More or less efficient?
    By grumpstumper in forum General Discussion
    Last Post: 01-13-2005, 01:01 PM
  4. ss fun at the tourne
    By mergs in forum New York - New Jersey
    Last Post: 11-29-2004, 09:58 PM
  5. to SS or not? that is the question
    By Nimai in forum Singlespeed
    Last Post: 04-28-2004, 11:46 AM
