Any alternatives to Chris King SS hub lockring?- Mtbr.com
Results 1 to 5 of 5
    I damaged the lockring for my Chris King SS hub. AVT has them, but they're $40. That's ridiculous! Are there any alternatives?
    MaxTheCyclist.com
    Reputation: mdilthey's Avatar
    Dec 2014
    Is the lockring proprietary? My LBS has like 200 of those kicking around. When I stripped the threads on a Surly lockring I just threw on a Deore one and was good to go.
    Ultralight bikepacking and gear lists... MaxTheCyclist.com
    Reputation: joshhan's Avatar
    Mar 2011
    Yeah I've got a generic one on my SS hub too.
    How about a gearclamp instead?
    Edit: link
    GearClamp - Singlespeed Conversion Kit
    Bikes, lots'o bikes
    May 2012
    The king lockring is proprietary because it threads onto the outside of the freehub and looks really clean with their special spacers. But I think that the last SS king hub I had also had standard lockring threads as well. You should double check the freehub. Otherwise, yes you will need the special one. You bought the mercedes of hubs, why would you think that replacement parts are cheap?
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious. :D
    The CK SS free hub body has same thread as BSA Bottom Bracket cup so you can use old "BB lock ring" for sure.
    I used to run it for speedy cog change (no need to chain whip). Hope it helps.
    -Aki
    "Semper Farcisimus!"
  1. King SPAM: BNIB Chris King Rear Hub w/ Fun Bolts Cheap
    By jonshonda in forum Wheels and Tires
    Last Post: 09-12-2015, 08:56 AM
  2. King SPAM: Clyde Worthy Chris King Rear Hub
    By jonshonda in forum Clydesdales/Tall Riders
    Last Post: 09-12-2015, 08:54 AM
  3. How's Chris King's CS?
    By Stripes in forum Wheels and Tires
    Last Post: 10-25-2014, 11:07 PM
  4. Chris King
    By THOWEDMODE2323 in forum 29er Components
    Last Post: 04-10-2014, 03:30 PM
  5. Replies: 8
    Last Post: 01-10-2012, 03:43 PM
