Another M960 mod- Mtbr.com
Results 1 to 23 of 23
    Super Moderator SuperModerator
    Reputation: driver bob's Avatar
    Another M960 mod
    Started butchering and polishing another set of M960 cranks last night.
    Picture shows the difference between an initial 220grit sanding and no sanding. By the time they are finished I will be up to a 1500grit and have a mirror finish.
    Cutting was all down freehand with a Dremel and ba$tard file.
    I have taken plenty of pictures of the whole process and will post more up and continuing progress as I do more work on them.
    Come see me after class
    Dec 2005
    looking forward to pics. i've been trying to pick up a set of these but they always sell too rich for me on eBay.
    I'd say go ahead and cut the spider's arm all the way down to the chain ring bolt hole's barrel. It's a tad lighter, and I think it looks even cleaner.
    My "OCD" likes having the 4mm amount of material left so the cut follows a smooth arc with the bolt hole.
    Here's a pic of the first set I finished:
    Dec 2005
    how many hours do you think you put into the first set?
    I didn't really keep track but it got to a point where my wife told me to stop before I went crazy !!
    It was a long cold winter....
    Polishing take a good while to do if you want a super nice finish, but the results are amazing, and last for ages. As with most things, and I'm sure Bob will attest, preparation is key.
    Reputation: batterhead's Avatar
    Are there any instructions on how to modify M960 cranks for single speed? I looked around, but did not find.
    pretty easy, saw - file - sand. repeat.
    Reputation: crazy8's Avatar
    Spider Tabs
    You can remove the material up to the barrels like BM says. Leaving this excess doesn't make them stronger. Your probably leaving 8g.
    Quote Originally Posted by bad mechanic
    Attached Thumbnails Attached Thumbnails Another M960 mod-facebook-update-photos-002.jpg
    Quote Originally Posted by batterhead
    I'm taking lots of pictures and when I'm done I will try my best to put something together. It might be later in the year though but basically:
    It is all about the prep to get a great finish, I will spend lots of time with the 220 getting everything clean and trying to remove as many "scratches" as possible.
    Non driveside: 400 Grit wet sand
    Driveside: 220Grit wet sand
    Difference is not that obvious in the picture but up close it is noticeably smoother.
    Also I'm losing my nails and fingerprints from the constant abrasion, it's a side effect no-one warns you about !!
    Dec 2005
    has your wife caught onto you yet?
    Low Rep Count
    Reputation: 1SPD's Avatar
    Looking good! I thought about doing this myself but I just don't have the time and I refuse to put the stock cranks back on my bike. So, I am cheating and contacted Crazy8 last night. Working on getting this taken care of w/ a quickness!
    Quote Originally Posted by alexrex20
    She's "kool 4 skool" with everything
    Dec 2005
    wait what?
    here's a set of 960s that should sell for a (relatively) low price. it only has the middle ring and it does not come with a BB.
    http://cgi.ebay.com/xtr-crankset-fc-...#ht_500wt_1154
    if the link doesn't work, it's item #120579415449
    sshhhhh...don't tell everyone. They've been on my watch list for days now.
    nothing to see here
    Reputation: Stevob's Avatar
    jeez, they're an ugly piece of work before you guys do your magic on them.
    I see hills.
    I want to climb them.
    Driveside: 600 grit
    NDS: 400 grit
    This is the time where the finish really starts to improve.
    DS: 600 grit
    NDS: 1500 grit
    Now we are getting somewhere !!!
    looks good, I paid a metal finishing shop a 100 bucks to remove the ano, polish, and clear power coat, and it was worth it. The Shimano cranks come out nice once they are polished.
    Having left this alone for 10 days or so I finally got to finishing them up yesterday.
    and up for sale too, I seen
