Another Basic cog/hub question....- Mtbr.com
Results 1 to 11 of 11
    Reputation: []D[][]v[][]D's Avatar
    I too am buildind up a budget SS...I bought a spacer kit from excelsports.com andI have a brand new 8-spd Shimano cassette. What do I do now??
    Never play leap-frog with a unicorn!
    Cracker-magnon
    Reputation: gpsser's Avatar
    Quote Originally Posted by []D[][]v[][]D
    Well, If you have a full set of spacers, I would go to the LBS and drop $5 on a Shimano DX bmx cog in the size that you desire (What gearing do you want to run?). take the cassette off and put it in the parts bin and use the spacers to get the desired chain line with the cog.
    "Life is a [email protected]#^ing story problem, get used to it - my son.
    And this will fit my traditional hub? i found a pic of a Shimano DX BMX cog and it looks like it wont fit
    Ebo
    Ebo is offline
    It will fit just right. I also got the spacer kit from Excel Sports and am using the Shimano bmx cog. They are dirt cheap at about 5 bucks.
    ballbuster
    Reputation: pimpbot's Avatar
    You bought spacers?
    You know you get 4 for free with each old worn out cog you convince the shop wrench not to throw in the trash, not to mention, you get 8 free gears to use. Get two old worn cogs, and you have a complete set of spacers, along with an assortment of cogs to play with. Just drill out the rivets or remove the tiny long bolts, and pop them apart.
    newbie boobie.
    Reputation: donkekus's Avatar
    Oct 2002
    Get FREE spacers, or make your own out of PVC..
    then get a King Kog.
    It ain't easy being human.
    This what I'm looking for??
    This the part I'm looking for?
    The man who fell to earth
    Reputation: Ziggy-Stardust's Avatar
    by george I think you've got it...
    That's eggs-zachary what you're looking for. Now all you need is a bit of PVC pipe, a hacksaw and you're all set man!
    Okay...now that I got my BMX cog and set of spacers, how do I lock everything on?? Am I missing a part here that does that?
    Whiskey Tango Foxtrot
    Reputation: eSSq's Avatar
    you need a lockring tool
    and maybe a chainwhip for later (if you want to change gears or if you don't get the spacing right the first time and you need to re-do it).
    Retro Grouch
    Reputation: aka brad's Avatar
    Idea! Yes, you need a lock ring..
    and probably the first cog (they work together to hold the lockring in place). If you look at gpsser's photo you'll see the first cog is being used. If you don't have an old casssette to pull from your LBS should have an old ring and cog they'll give you (or at least save one for you). If you get desperate let me know I got a few extra.
    Brad
  1. Brake response question? and Slider pressure question?
    By Gnar in forum Downhill - Freeride
    Last Post: 09-05-2004, 03:20 PM
  2. Newbie Lbs question
    By joshua_msu in forum Riding Passion
    Last Post: 03-15-2004, 10:13 AM
  3. Turner Burner or Titus RX 100 for 24 hour race bike
    By sperky in forum Bike and Frame discussion
    Last Post: 02-10-2004, 02:27 PM
  4. real basic question...
    By cudevil in forum Shocks and Suspension
    Last Post: 01-30-2004, 10:37 AM
