Aluminum cog on aluminum free hub body?- Mtbr.com
Results 1 to 3 of 3
    Reputation: Sweeney's Avatar
    Nov 2006
    Will it work or will it chew into the splines? I'm building up my first singlespeed and would like to use my existing wheels until I can get a single speed set. So what do you think, will it be OK to use a alu cag with a 4 or 5 mm base or should I wait until I can get a new wheelset?
    Feb 2007
    yes it'll be ok
    Reputation: boomn's Avatar
    Yep, 4-5mm should be enough width for any kind of cog to work on an Alu freehub body. That is the normal width for all the nice steel ones out there
