Alt bars - help with stem- Mtbr.com
    Okay, building up a new bike, going to go with Ragley Carnegie bars (carbon). I've never ridden an "alt" bar before, so I need a little insight.
    Current ride is a Spec. Stumpy SS (large), setback post, 105 mm stem running at flipped (it's either -10˚ or -15˚). I'm running straight, flat, and wide carbon bars and a Niner carbon fork.
    New build is a Salsa Selma Ti SS (large), plan to use the same setback post, and Ragley Carnegie bars (not the inverted ones). I don't have access to a wide variety of stems to play with, and I'll be running another Niner carbon fork, so cutting the thing correctly is kind of important. I am guessing a 100mm Thomson 0˚ stem (knowing that I may end up having to swap it out at some point).
    I'm just a little over 6' tall, fairly normal proportions I guess. Is the 100mm stem a good starting point with the Carnegie bars?
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    I can only figure that stuff out with trial and error. Maybe some friends will let you borrow their spare stems in various sizes. Consider it a bump!
    Raised in a Chicken-Coop by Chickens
    Gotta pay to play
    Reputation: michaelscott's Avatar
    Quote Originally Posted by architectx View Post
    Yes.
    I'm just messing with you
    Reputation: wv_bob's Avatar
    The manufacturer may be able to tell if additional stem length is needed to put your hands in the same place as they would be with a straight bar. Or you can figure it out yourself like I did with this fu-bar.
    Attached Thumbnails Attached Thumbnails Alt bars - help with stem-img_4571.jpg
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
  1. Replies: 15
    Last Post: 11-27-2009, 07:54 AM
  2. Question about J-bars or H-bars and stem length
    By Lucid in forum Singlespeed
    Last Post: 02-20-2009, 01:22 PM
  3. Bars and Stem
    By chrome_buttons in forum Urban/DJ/Park
    Last Post: 07-05-2007, 02:54 PM
  4. Stem and bars
    By Redmon in forum General Discussion
    Last Post: 05-07-2007, 11:56 PM
