Adjust Kona Unit chain tension - noob alert- Mtbr.com
Results 1 to 13 of 13
    Oct 2014
    I searched and didn't find a clear answer, so here goes: I have a 2014 Unit, and I've popped into the LBS I bought it from once so far to adjust the chain tension, after it's initial stretching out phase. It's starting to loosen up a bit again, and this is maintenance that I certainly want to be able to do on my own. It LOOKS simple, but being very non-mechanically-inclined, I fear I don't know the whole picture. Plus, I have very few bike-specific tools, only one of these: http://www.crankbrothers.com/product/view/143 and a pedal wrench. I have other basic tools of course, but that's as far as my bike toolbox goes.
    Is it as simple as: loosening the 4 bolts, pulling the wheel back, adjusting the two little set screws to set everything in place and then re-tightening the 4 bolts? Do I need a torque tool, or can I just go by feel?
    It's gotta be something even I can handle--perhaps I'm over-thinking it! Thanks in advance.
    Oct 2010
    you've got the sequence right but just use the set screws to move the wheel back, doing an equal amount of turns on each side to make sure the wheel stays centered.
    Oct 2014
    Quote Originally Posted by jmctav23 View Post
    Thank you! I tend to over-think things, and thought there must be some step I'd be missing. Will give it a go.
    Wanna ride bikes?
    Oct 2013
    yeah, it's as simple as you think it is. maybe just instead of an equal number of turns, just make sure the wheel is centered in the frame.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Oct 2014
    thanks for the tips!
    Clyde on a mission!
    Dec 2011
    The drill I use on my unit:
    1) Loosen the two big bolts on both sides and undo the small nuts on the adjuster screws too.
    2) Use the adjuster screw on the chain side to tighten the chain, not too tight, leave a little slack in the chain.
    3) Tighten up the big bolts on the chain side, I prefer using a torque wrench, but going by feel works too.
    4) Use the adjuster screw on the non-drive side, while eyeballing the wheel close to the crankbox. You'll want the wheel to be centered between the left and right stays.
    5) Once the wheel is nice and centered between the stays you tighten up the two big bolts on the non-drive side.
    6) Check that the wheel is centered once more and that the chain hasn't become too tight.
    7) Lock the adjuster screws with the small nuts.
    In general I recommend getting a small torque wrench that'll do 0-15 Nm or so, most motorcycle shops have them at a reasonable price. I've got one of these https://www.louis.de/en/artikel/prof...?list=61099051 and it has served me for years - just remember to set it to it's lowest setting after use so you don't ruin the calibration.
    Using a torque wrench really shines everywhere that more than one bolt shares a workload, for example the two bolts each side holding the sliding dropout in place or the four small bolts holding the handlebar in place and so on. If you do the bolts up by feel one will be tighter than the other, doing the majority of work, while the other tends to work itself lose over time. Torquing them equally makes sure they stay tight. It doesn't really matter if you torque them at 8 or 10 or 11 Nm as long as both get the same torque (and you don't overdo it and strip the threads naturally).
    Oct 2014
    Fantastic--thanks for the details. I'm planning on building up my bike-specific toolkit, and a torque wrench is on my list!
    Oct 2014
    Well I finally decided to give this a go, and I'll be damned if I can't budge the bolts at all!
    My little multi-tool is apparently not up to the task---they are crazy tight. Makes sense I guess, that they'd NEED to be tight to be safe, etc. but man, I practically bent my multi tool trying to loosen 'em. Back to the LBS for now, until I get a more mondo wrench in my arsenal I guess….
    Oct 2010
    Just get a decent set of allen keys and use a tube of some sort to get more leverage
    nothing to see here
    Reputation: Stevob's Avatar
    Yup. Leverage is your friend.
    I see hills.
    I want to climb them.
    Wanna ride bikes?
    Oct 2013
    agreed, multi-tool is not up to the task!
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    LBS over tightened them. I'd take it back and make sure they do it right the second time.
    Maybe they used loctite on the threads. Geez, I hope not...
    Oct 2014
    Took it to the LBS and he got 'em loose no prob, so no lock-tite!
    I just need some better tools. Seriously, I was starting to bend my multi allen tool trying to loosen those damn things!
    The problem is, this "LBS" where I bought it isn't really local--it's about an hour away(I have others very close by, but I'm still milking my 6mos of free tune-ups, etc. with LBS I purchased the bike at).
    Anyhow, I plan to get tooled up--crazy to drive even just across town to do a tweak this simple.
  1. Replies: 9
    Last Post: 02-10-2015, 07:15 AM
  2. Incoming Kona Unit - quick noob question
    By jbass in forum Singlespeed
    Last Post: 12-20-2014, 11:54 PM
  3. 2013 Kona Unit or 2014 Kona Unit
    By evosil98 in forum Singlespeed
    Last Post: 12-10-2014, 10:06 AM
  4. Chain for Kona Unit
    By drjay9051 in forum Kona
    Last Post: 07-15-2013, 04:06 AM
  5. Replies: 17
    Last Post: 10-13-2012, 12:42 PM
