ACS FW illness- Mtbr.com
Results 1 to 7 of 7
Thread: ACS FW illness
    being is
    Reputation: pseudo intellectual's Avatar
    ACS FW illness
    My ACS FW is making more than just the usual knocking. Every once in a while it makes a loud PING! or CLANK! it's kind of like a very loud knock. I used to think it was the chain trying to get off the chainring and then popping back on but now I believe it is coming from inside the freewheel. Must be the set of pawls that do not catch, catching just enough to make the noise like snapping your fingers... Make sense? Anyway, does this mean my FW is about to break its pawls? Doesn't sound good at all.
    el cheapo
    Aug 2005
    I would think one of the pawls has or is about to liberate itself from its usual home, time for replacement!
    I am CHEAP
    nachos rule!
    Eno...
    plus a change, plus c'est la m'me chose - alphonse karr
    Reputation: shiggy's Avatar
    Dec 1998
    Time to replace it.
    mtbtires.com
    Misfit Psycles
    Reputation: nogearshere's Avatar
    Mar 2005
    if you decide to replace it with another ACS buy two or three and save yourself a trip to the shop...
    it has been said before...ENO...
    Expert of the Internet.
    BECAUSE I SAID SO
    cause it's fun
    Be Careful
    I had an ACS give out as I was chugging up a hill. It started with the typical "ACS knock", then a few loud pops, and finaly it gave out. Sounds very similar to what you are experiencing.
    It does hurt oIo
    bus driver wanna be
    being is
    lube
    Quote Originally Posted by nogearshere
    I squirt rock n roll extreme into the FW on a pretty regular basis and get good life out of them. Mine seem to last a year or so. The teeth wear out first usually. Same thing would happen w/ an Eno, but I wouldnt have to lube the Eno.
    Maybe when I run out of ACS FWs I'll try an Eno. It will be a few years at the current rate of attrition tho.
  1. Are ACS freewheels any good?
    By 11 Bravo in forum Singlespeed
    Last Post: 02-01-2006, 10:20 AM
  2. acs freewheel spanner report
    By single1x1 in forum Singlespeed
    Last Post: 06-24-2005, 06:20 AM
  3. Noisy ACS Claws
    By Legbacon in forum Singlespeed
    Last Post: 11-18-2004, 06:48 AM
  4. Replies: 13
    Last Post: 11-17-2004, 02:24 PM
  5. ACS freewheel
    By Dude! in forum General Discussion
    Last Post: 04-16-2004, 01:29 PM
