952 XTR chainring options?- Mtbr.com
Results 1 to 14 of 14
    I know that Spot makes one, but they only show a 35t, and I'm after something 32t.
    Any suggestions?
    BN
    get an xt spider (lx won't fit), then use any 4 bolt/104 down you'd like.
    Reputation: Nater's Avatar
    Spider or Boone
    You can have Boone make you a spiderless ring in any size you want for those arms,
    or have your LBS order this spider from BTI and run any 4 bolt ring you can find...
    http://www.bti-usa.com/item.asp?item...wSec=0&filter=
    Quote Originally Posted by Nater
    True, I can just get one of those. I like the cleaner look of the other rings. Maybe I'll just go that route though, it'd be easier for sure...
    DHS
    DHS is offline
    Reputation: DHS's Avatar
    I don't think
    Quote Originally Posted by DHS
    any of those are a direct fit for M952 XTR crank arms. The rings that they lable XTR are for the M960 series cranks that have a 102mm BCD for the middle ring.
    Which one of those is for the m952 cranks?
    DHS
    DHS is offline
    hm strange. not on their site anymore. give them a call, i use to run their rings on my old xtr cranks
    Reputation: dirtdirt223's Avatar
    Mar 2006
    when i had 952's on my ss, i ran a boone 32 tooth chainring. it is a very clean looking setup and you dont need a spider to mount it up.
    contact the path bike shop by telephone. they usually have a supply of boone products on hand. for some reason, the boone products do not show up on their web site.
    http://www.thepathbikeshop.com/
    Quote Originally Posted by dirtdirt223
    I'll drop Boone an email then, thanks for the info.
    Reputation: jimmyboy's Avatar
    Feb 2006
    I just the Redline 29er and it rocks. Plus I will be giving away two 29ers , 2 Felts and one other bike, some new Niterider Lighting systems and $6000 in prize money at the Coolest 24 hr race on May 5th & 6th www.thecoolestmtb.com
    Sep 2004
    The Spot ring only comes in 35t and its 140 bucks retail.
    Quote Originally Posted by ss34x18
    Not really worried about retail honestly, mostly about the size. 32t is what I want.
    IFSDlxSS IFTiFLWMtb GFAdv
    Reputation: Spidey-Lag's Avatar
    Sep 2004
    Quote Originally Posted by BikeNerd2453
    Boone Rings will do it for you.... It may take a couple of weeks to have it made but it's worth the wait.
